1. Vance14's Avatar
    A problem has developed in the last couple of weeks on my Nexus 7. The WiFi radio seems to be acting up, with a much weaker connection then my Galaxy Nexus sitting right next to it, and sometimes when I do a speed test there is no up speed at all. What could the problem be and, short of flashing the new radio, what can I do?
    03-23-2013 11:31 PM
  2. B. Diddy's Avatar
    Have you tried rebooting your Nexus 7 as well as your router? If these approaches don't work, there might be a loose connection. Check out this thread--there's a description on how to pop open the back cover to access the wifi antenna:
    http://forums.androidcentral.com/goo...rformance.html
    03-23-2013 11:52 PM
  3. Vance14's Avatar
    Ok, I figured it out. I had dropped it a couple of days ago in the back cover had popped off and when I snapped it back on I left one corner loose and the connectors to the WiFi radio were not solid. So I reseated the back cover and everything seems to be fine now.
    B. Diddy and liljew like this.
    03-23-2013 11:59 PM
  4. Vance14's Avatar
    Ah, we cross posted, and you were right, it was the connection, and even better, it was just my own failure to snap it back together, so the connections themselves were not bad.
    B. Diddy likes this.
    03-24-2013 12:02 AM
  5. B. Diddy's Avatar
    Cool, glad you figured it out! Perhaps it's time to get a case for that baby ...
    Vance14 likes this.
    03-24-2013 12:21 AM
  6. Vance14's Avatar
    I had a case, but then I got the dock and the case won't fit. And I was going on about how it was perfectly save in the house!
    03-24-2013 05:13 PM
  1. WiFi connection problems
    By yogibimbi in forum Other Sony Android Phones
    Last Post: 10-04-2010, 02:16 PM
  2. evo wifi radio suffering from same iphone4 grip issue?
    By cheebahawk1 in forum HTC EVO 4G
    Last Post: 06-30-2010, 09:46 PM
  3. EVO FM Radio Problems
    By Redraider1 in forum HTC EVO 4G
    Last Post: 06-24-2010, 09:28 AM
  4. Wifi streaming problems?
    By shaunm89 in forum Google / HTC Nexus One
    Last Post: 06-13-2010, 01:33 PM
  5. WIFI connection problems
    By Raija in forum HTC Desire
    Last Post: 05-20-2010, 05:24 AM
