Nexus 7 WiFi problems
Ben Paterson
54
I recently got a problem with my nexus 7. It connects to the internet but the WiFi icon is grey. Chrome works but the play store and YouTube etc does not work, if anyone can help I would be grateful :)
MJKearney
815
Try rebooting your WiFi router. That's the easiest first step. Report back if it doesn't work (or even if it does work).
rxgadget
730
3
Try turning airplane mode on waiting a but then off. Also can try flipping the wifi off and on. This is the only way I can get mine to work
lmvine
127
Mine does it (gray icon) when there are competing wifi on the same channel at about the same signal strength.
It also seems to do more often with the latest Android update.
It has become clear to me that the N7 is a beta device that Goog uses to test their software and probably hardware. Less enamored with it than initially. Concept great but implementation not so much.
lmvine
127
Wifi fixer seems to work for me but I need to try in more locations to be sure.
There are other wifi "fix" apps in the play store. Maybe one of them would work.
rxgadget
730
3
I have finnaly fixed it, what I have done is I installed smooth ROM and now the WiFi is working well :)
Wonder what was done in the Smooth ROM to get wifi to stay blue and not swap to gray randomly.
Sent from my Nexus 7 using Tapatalk HD
lmvine
127
Well I tried in a location I used to work OK & it doesn't connect. Stays gray.
Back to square 1. There are many discussions of this on net.
akbarramadhani12
