1. leelee0431's Avatar
    I have a nexus 7 tablet which I love apart from the fact that when I plug in my head phones it restricts me from turning up the volume more than half way !!! Is there anyway to turn off what I presume is a safety feature ? As it is making it difficult to use the tablet for the purpose I bought it for which is for when I commute as at the moment unless I'm some where quiet I can barely hear the audio.
    Thanks leelee0431
    08-28-2013 02:19 PM
  2. B. Diddy's Avatar
    When you get that warning, you should be able to keep going up on the volume afterwards. It should just be a warning, not a prohibition. Is it not letting you do that?
    Sent from my DROID RAZR using AC Forums mobile app
    08-28-2013 02:36 PM
  3. repligation's Avatar
    I believe that the volume warning was a "feature" in 4.2. Since updating to 4.3 I have not encountered it again on my n7 and I use my headphones every day.
    08-28-2013 05:01 PM
  4. Dana Nairn's Avatar
    I have the same issue with Netflix. It's not the warning message like in other apps, it just won't go any higher. In fact, if you keep pushing the volume button, Netflix freezes up completely. I haven't been able to find a solution.
    08-28-2013 09:06 PM
  5. leelee0431's Avatar
    This is the issue I am having I receive no warning I am just unable to tire the volume up more than half when headphones are plugged in on anything not just netflixs .
    08-29-2013 09:33 AM
  6. leelee0431's Avatar
    I have no warning at all it just refuses to allow me to increase the volume more than half.
    08-29-2013 09:36 AM
  7. leelee0431's Avatar
    Quick fix - put head phones in well on tablets home screen turn volume up well on home screen and cancel the warning (which does not appear when turning volume up in an application) u should then be able to increase the volume past the half way mark. You may have to do this each time you use the headphones.
    le_prof and ECBabic like this.
    08-29-2013 02:38 PM
  8. dannyd86's Avatar
    09-04-2013 10:42 PM
  9. James MacLochlainn's Avatar
    Just found your solution. Thank you, took me an hour to find it.
    09-19-2013 11:44 PM
  10. le_prof's Avatar
    Thanks for the workaround! Just couldn't find it on my own!
    Envoy de mon Nexus 5 en utilisant Tapatalk
    02-21-2014 10:12 AM
  11. pezza37's Avatar
    I hated having the volume warning on, it was driving me mad so thank you Dannyd86 for the link to hearing saver, it has made me a happy man.
    03-09-2014 02:39 PM
  12. Chandrakant kane's Avatar
    I was also in trouble with my Nexus 7 .I used the same method of clicking Cancel tab.But that created another problem after removing the headphone the volume control stopped working linearly.
    03-17-2014 03:04 AM
  13. daveq2's Avatar
    Couldn't get netflix volume above a whisper on my Nexus 7. Hearingsaver solved the problem. Thanks!
    08-13-2014 04:16 PM
  1. Sol Republic headphone controls
    By Clintg37 in forum Moto X (2013)
    Last Post: 05-20-2014, 10:46 AM
  2. QI Pad that will charge nexus standing up
    By andy barton in forum Google Nexus 7 (2013) Accessories
    Last Post: 11-01-2013, 11:21 AM
  3. Channeling my inner Jerry
    By Theot in forum General News & Discussion
    Last Post: 08-29-2013, 02:24 PM
  4. Why is Google Play Music draining my battery?
    By Markersk in forum AT&T Samsung Galaxy S4
    Last Post: 08-29-2013, 11:33 AM
  5. Way to quickly mute Ringtone without using Vibrate or Mute mode?
    By ummdav1d in forum General Help and How To
    Last Post: 08-28-2013, 05:47 PM
