11-12-2015 06:40 AM
44 12
tools
  1. Dylan Boudreau's Avatar
    Hi all,
    As the title says if I use my nexus 7 tablet until the battery runs dead then plug it in and charge it I can't get it to turn back on unless I connect it to a computer. As soon as I connect it to a computer and push the power button it powers up normally and works without issue. Once I get past that the power button works fine as do the volume buttons but for the life of me I can't figure out why I need to connect it to a computer for it to start after I run it empty so any advice would be helpful.
    09-13-2013 06:20 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! I'm afraid I don't have a concrete answer for you, but I would say that in general, it's best to avoid running your device all the way down until it shuts off on its own due to low battery. Completely discharging a Li ion battery is a good way to damage it irreversibly, and although I know that all devices should automaticaly shut down well before you get to zero, there's still risk, since you might not plug the device in promptly to recharge.
    One thing I would check is to make sure your charging block still works. Will the tablet charge up when plugged into the wall at other times when the battery isn't really low?
    09-13-2013 09:29 PM
  3. freakshow999's Avatar
    I know when I've let my battery go completely dead I have to hold the power button on for much longer than usual for the initial boot up. It may just be you're not holding the button long enough.
    Sent from my HTC One using Tapatalk 4
    09-13-2013 11:33 PM
  4. red.foxx15's Avatar
    are you using the original charger block and cable that came with the nexus 7? ive had similar issues due to trying to use my nexus 4 charger when i ignored my 7's battery indicator
    09-14-2013 02:32 PM
  5. torndownunit's Avatar
    I found this as well. I also found it seemed to take awhile for the charging to start.
    09-14-2013 02:36 PM
  6. Dylan Boudreau's Avatar
    Hi, yes I'm using the original charger block and cable. Seems to charge without issue even when it won't power on. When I do get around to connecting it to a computer to start up after a dead battery it reports that it is fully charged so that seems to happen even when the device won't boot.
    It's a very odd problem and I'd love to know the reason for it as now I can't travel without a computer in case the battery runs dead while travelling which on a cross continent trip happens just about every time.
    Oh and I've held the power button down for upwards of a minute and still doesn't come on but connect to a computer and it powers on in only a few seconds.
    09-15-2013 06:29 PM
  7. Dylan Boudreau's Avatar
    Guess I'm the only one that has had this problem ...was really hoping someone else would have seen this as I'm at a total loss as to how to fix. I've tried really hard to not let the battery go dead but still happens sometimes, particularly if I use it before bed when the battery is already down.
    John Courtney1 likes this.
    10-05-2013 02:51 PM
  8. f10w3r5's Avatar
    I'm having the same issue except mine won't boot at all.. I let mine run all the way down, charged it, and now it's stuck on the little splashy X thing. Won't get by it. Grr....
    Susan Salinas likes this.
    10-13-2013 07:32 PM
  9. Stew Craig's Avatar
    Actually people, its an easy fix (once you know how), connect to mains power then just press both the power button and the volume increase button at the same time and keep pressing till Google appears on screen. It's just a glitch that can happen if you leave the Nexus 7 idle for a long period of time, or if you let the battery run down completely. I hope that helps!
    11-08-2013 01:36 AM
  10. Randy Laws's Avatar
    Thanks Stew! That worked for me.
    11-08-2013 05:35 PM
  11. Khashayar Parham's Avatar
    my nexus7 baterry is not able to charging.how i can fix it?
    12-09-2013 03:39 PM
  12. benhmadison's Avatar
    Don't let the battery go completely dead on any modern devices. I understand you are away from a charger sometimes but you can still shut down the device at 10-15 percent until you are able to charge.
    It's not a problem or a defect, just don't run it all the way down.
    Ntchwaidumela likes this.
    12-09-2013 03:43 PM
  13. CookyBoy's Avatar
    thanks for this, it helped me.
    12-17-2013 02:22 AM
  14. Hayden Heun1's Avatar
    it wont work for me
    01-01-2014 03:41 PM
  15. Danny Vaper's Avatar
    Here's a video that may help.
    https://support.google.com/nexus/tro...r/3337561?rd=2
    Posted via Android Central App with 2012 N7
    01-02-2014 08:06 PM
  16. Netsirkf's Avatar
    I have a slightly different battery issue, after charging on a third party charger overnight, my 1st gen nexus 7 flashed the on screen battery empty signal the next morning. It only showed a couple of times before the device died completely and has showed a black screen ever since. I've tried every combination of holding the power and volume buttons, as well as plugging it into the official charger and a computer, I'm getting no response from the unit. I've checked the battery connection and it's fine, even disconnected it and left it off a bit to see if that prompted a restart.
    Replacement batteries are way expensive for a unit that now retails at 99 so I'm really not sure it's worth going that route, anybody got any ideas?
    Thanks
    01-04-2014 02:24 PM
  17. Tom Wozniak's Avatar
    Google's help center offers that you can backdoor the boot by pressing 'volume down' and then holding the 'power' button for 10-15 seconds.
    My wife let hers sit in a computer case for months and it is now taking a long while to charge.
    This is the link to google's help & solution: https://support.google.com/googlepla...337942,3339328
    02-27-2014 12:55 PM
  18. Khanitez's Avatar
    Thanks Stew Craig.
    Your advice worked for me. Not sure why it died as my battery was at 97%
    sailpowerd likes this.
    03-01-2014 06:01 PM
  19. RainFace DeathMonkey's Avatar
    Guys, listen to him. I've had this problem many times, and he was 100% dead on. Hold the power down for much longer than normal, and it should start right up.
    03-02-2014 11:17 PM
  20. Sasha Edwards's Avatar
    HELP! I have unfortunately let my Nexus 7 die a few times due to neglect. It is fully charged and yet I can't seem to get it to turn on completely, it seems to get stuck on the screen after the Google screen...I'm extremely frustrated. I've tried EVERYTHING that I've read to try and yet no results. Super bummed. Any new tips I could try?!
    Thanks!
    03-03-2014 01:16 PM
  21. Ghellie Serrano's Avatar
    it's happens to my android too but not nexus
    03-09-2014 12:28 AM
  22. B. Diddy's Avatar
    Thanks!
    Welcome to Android Central! It'd be helpful to specify some of the things you've tried, because if you just say "everything," many people probably won't bother answering, since they'll assume you've truly tried every single solution.
    The first thing that I would suggest is to boot into recovery and try wiping the system cache partition: http://forums.androidcentral.com/goo...tion-wipe.html
    03-09-2014 12:34 AM
  23. David Brown14's Avatar
    You are not alone! Mine behaves the same way when left too long in my backpack. Thanks for teh tip about connecting to a computer - I hadn't tried that.
    03-22-2014 07:40 AM
  24. April Southerland's Avatar
    It works, I have the same problem. If I let my Nexus 7 get kinda low before I plug it up over night, when I try to turn in on the next morning it acts all caddy whompus. I just held the power button longer the normal and it came on. I was actually considering trying to get mine exchanged or something, thinking it was a bad tablet. It works if you just hold the button a little longer. I held it long enough to look up at the TV and back down at it and it came on, I looked up slowly so don't give yourself whiplash or anything lol.
    Kinda wishing at times that I had went with a Hannspree tablet I found on Amazon.
    03-27-2014 11:08 AM
  25. andy_scot_uk's Avatar
    Thanks very much for this. I've had problems for months with this and now its fixed.
    03-29-2014 01:09 AM
44 12
  1. How to avoid automatic download of all your purchased apps...
    By unlic3nsed in forum Google Nexus 7 Tablet (2013)
    Last Post: 04-30-2014, 01:47 PM
  2. To screen protect or not
    By skatergirl in forum Motorola Droid MAXX
    Last Post: 09-14-2013, 01:42 PM
  3. Nexus 7 battery/wallpaper problem
    By neffyh in forum Google Nexus 7 Tablet (2012)
    Last Post: 09-14-2013, 02:31 AM
  4. Battery usage acceptable?
    By hjanweja in forum Moto X (2013)
    Last Post: 09-14-2013, 02:00 AM
  5. N7 2013 won't recognize wifi 5ghz
    By Pipo Acious in forum Google Nexus 7 Tablet (2013)
    Last Post: 09-13-2013, 05:00 PM
