1. Ken98045's Avatar
    OK, I let my Nexus 7 die to to low battery. I refused to come on even when reconnected to power. I used the Change/disconnnect/connect/power 15 sec trick to get the device to come on at all. Power is now about 15%.
    Now, things are strange with WiFi. I can use any browser to connect anywhere on the net. However, I cannot use embedded network connections - play store - other apps to connect. It seems like WiFi should either be on, or it should be off. It shouldn't be somewhere in the middle.
    Also, date/time is 12/31/1999. Presumably this is because it can't connect?
    I realize that possibly a full charge may fix things, but I'd like to know what is going on. It seems like a low power level shutdown of features should affect all programs equally. Why can a browser work, but not other apps?
    09-20-2013 10:59 PM
  2. Haalcyon's Avatar
    Welcome to the awesomeness that is Android Central! Is the device rooted or ROM'd, this does indeed sound strange. I wonder if a factory reset would help.
    09-21-2013 06:06 AM
  3. josuerios777's Avatar
    Strange indeed. Try factory reset if the problem persist. Otherwise it seems like you're missing some sort of Google services apk on your device. If the latter is the case, I think you'll need to get rooted and manually install it. I know I once received a defective android phone that there was problems with play store. It was missing an apk. Good luck!
    Posted via my lag-free, always updated Nexus 4
    09-22-2013 05:06 AM
  1. Unhappy with firmware update
    By jennapi in forum Samsung Galaxy Tab 2
    Last Post: 07-08-2014, 07:33 PM
  2. i've format my nexus 4 please help me!
    By siaaldo in forum Google Nexus 4
    Last Post: 09-21-2013, 10:08 AM
  3. Just bought the Nexus 7
    By asanatheist in forum Google Nexus 7 Tablet (2013)
    Last Post: 09-21-2013, 09:41 AM
  4. Help with monthly billing math question
    By ManiacalMF in forum Verizon
    Last Post: 09-20-2013, 10:50 PM
  5. Nexus 4 text preview notification problem
    By weathdish in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 09-20-2013, 04:01 PM
