1. Live2ride883's Avatar
    The charging port on my daughters Nexus 7 (2012) will no longer charge her tablet. The cable is really loose in the port, and the charger will charge other devices. Where can I find the port at, or do I have to send the unit back to Asus?
    12-23-2013 08:07 PM
  2. Paul627g's Avatar
    This would be something ASUS or authorized/reputable repair store would have to fix. Most situations I believe they just swap out the entire motherboard since its connected but there maybe a shop that would attempt just replacing the USB port but again I would only go this route if they have a proven reputation with some sort of warranty on that type of replacement.
    12-23-2013 08:18 PM
  3. Live2ride883's Avatar
    Thanks....
    12-23-2013 08:23 PM
  4. Live2ride883's Avatar
    Has any one had this done or know how much it costs?
    12-23-2013 09:42 PM
  5. bloo0153's Avatar
    You could get the dock. It uses the pogo pins for charging.
    Sent from my Nexus 7 using Tapatalk 4
    12-23-2013 10:03 PM
  6. myhui's Avatar
    Where and what are the pogo pins?
    I thought the Nexus 7 can only be charged via the USB.
    12-23-2013 10:10 PM
  7. sampoodle's Avatar
    Pogo pins are on the bezel part at lower left of unit when looking at the unit in "portrait" mode. Four brass dots.
    These contact spots mate with the pins on the charging dock, which looks like a long rectangle with a slot for the N7 to sit in.
    I love my charging dock! I hardly use the USB connector
    12-23-2013 10:56 PM
  8. retsaw's Avatar
    The USB port is not directly attached to the motherboard, it is connected by a detachable ribbon cable and should be fairly easy to replace yourself (have a look at the iFixit teardown). Although replacements are, at $50 on eBay, more expensive than I expected them to be, it is just possible that Asus might be able to repair it cheaper since the part itself couldn't have cost them more than $5 to manufacture in bulk.
    Sent from my Nexus 7 using AC Forums mobile app
    12-24-2013 03:45 AM
  9. myhui's Avatar
    I just got mine from Newegg and agree with you that it is an essential accessory.
    But what about the newer edition of the Nexus 7? Does that have its own dock too? I can't seem to find a dock for the 2013 model of the Nexus 7.
    12-24-2013 03:49 PM
  10. myhui's Avatar
    Your pictures are not showing up.
    A dock for the 2013 Nexus 7?
    I thought the dock only fits the 2012 model.
    12-25-2013 04:14 PM
  11. amsparky's Avatar
    I had the same problem. After sending it back to Asus twice, I bought the dock and have no more issues.
    12-25-2013 10:02 PM
  1. Galaxy Tab 3 - Won't Charge
    By GumbieuK in forum Samsung Galaxy Tab 3
    Last Post: 09-05-2016, 04:42 AM
  2. HTC One Battery Not Charging/Holding Charge
    By Justin Peeler1 in forum AT&T HTC One
    Last Post: 05-27-2016, 04:59 AM
  3. Problem in battery drain Note 3
    By ossamoha in forum Samsung Galaxy Note 3
    Last Post: 02-06-2014, 08:48 PM
  4. Replies: 7
    Last Post: 12-26-2013, 10:21 PM
  5. Problems copying files from my pc to Nexus 7 (2013) ?
    By jerrysimon in forum Google Nexus 7 Tablet (2013)
    Last Post: 12-24-2013, 02:07 PM
