Results 1 to 3 of 3
    Default Help Nexus 7 won't charge
    Hi. My nexus 7 will not charge. When plugged in it does not charge. The charging port wiggles around and seems loose. Has anyone lese encountered similar problems and found a fix?
    Thanks
  2. #2
    codeda's Avatar
    Posts
    Global Posts
    331 Global Posts
    Default Re: Help Nexus 7 won't charge
    My best friend had this issue a few months back. We tried everything we could think of but ended up having to just RMA it. You might have to go that route as well. Faulty charging port. Good luck!
  3. #3
    amsparky's Avatar
    Posts
    Global Posts
    68 Global Posts
    Unfortunately it's very common. Do the RMA or if you don't want to ship it off, buy the dock. I bought the dock when mine stopped charging and it works great!
    Good luck!
  1. Charging Problem
    By CursiveTea in forum AT&T Galaxy Note 2
    Last Post: 02-26-2014, 07:08 PM
  2. Nexus 10 Screen replacement
    By Nas415 in forum Google Nexus 10 Tablet
    Last Post: 01-20-2014, 10:21 AM
  3. Nexus 7 wifi question
    By darktwins25 in forum General News & Discussion
    Last Post: 01-07-2014, 12:10 AM
  4. Getting a replacement Nexus 5
    By chris taylor10 in forum Google Nexus 5
    Last Post: 01-06-2014, 05:23 AM
  5. Need help programming bluetooth HID
    By noer396 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 01-05-2014, 10:16 AM
B
