Results 1 to 3 of 3
    Default Replacement power cable impossible to get
    Hello,
    I have a problem with my nexus 7 (google, 2012, 3g) were it randomly turns on and off. It has happened since I got it a few months ago but cant be bothered to take it back or get it repaired. The problem doesn't occur too often either, perhaps once a week so if I did send it back, it would probably be fine for them and send it back untouched.
    I believe it is the power/volume flex cable. I can fix the problem by simply taking off the back of it. A close look at the contact points shows that the power contact is flatter then the volume contacts, so I believe very little pressure causes it to 'activate'. Taking the back off relieves the pressure.
    I ordered a new cable off ebay but discovered it is wrong. The one they sent has 4 contact points where as mine only has 3. the connector also has 2 right angles (so the connector faces the same way as the cable) where as mine only has 1, facing inwards. Another look online only shows the 4 point cable. I cant seem to find my cable anywhere.
    Any ideas?
    Cheers. (and sorry for the long story)
  2. #2
    srkmagnus's Avatar
    Posts
    Global Posts
    13,694 Global Posts
    Carrier
    Stock 4.4 (KitKat)
    Default Re: Replacement power cable impossible to get
    Quote Originally Posted by jamesisasecret View Post
    Hello,
    Any ideas?
    Have you always had this issue? I would suggest a factory reset and monitor it to see if the problem persists. Also give it a full charge and see how it performs afterwards. I would also pay close attention if the issue restarts and see if there was a service or App you installed around that time. That could also be an issue (bad App) and is causing the device to shut off or reboot.
    Hello,
    Cheers for the reply. It has happened pretty much since I had it! I have done a few factory resets and the problem has always been there. It also occurs in Bootloader. My device is unrooted.
  1. Want to try T-Mobile for a month
    By slik6996 in forum Google Nexus 5
    Last Post: 01-28-2014, 01:43 PM
  2. Any former Note 3 users that have converted to the Moto X
    By ballisticn8 in forum Moto X (2013)
    Last Post: 01-26-2014, 12:33 AM
  3. Add IR capabilities to Nexus 7 FHD
    By William Miller 3 in forum Google Nexus 7 Tablet (2012)
    Last Post: 01-25-2014, 07:44 PM
  4. Why can't I go back to 4.1 android with the reset?
    By Elysium82 in forum General News & Discussion
    Last Post: 01-25-2014, 03:44 AM
  5. How to use Air command without taking out s-pen
    By Amir in forum Samsung Galaxy Note 3
    Last Post: 01-24-2014, 02:12 PM
