1. kal1209's Avatar
    I accidentally spilled some milk on my Nexus 7. Some of it went into the headphone jack and started making clicking sounds like I was typing. After tapping the top of the device on my bed to get the milk out it seems perfectly normal. Is it this durable or did I just get lucky? I have geek squad accidental protection with it but I don't see a reason to bring it to them since it works fine. Thank you.
    08-22-2013 11:00 PM
  2. Golfdriver97's Avatar
    Keep an eye on it over the next few days. I think you made a major withdraw from the Luck Bank.
    Deanig_12 likes this.
    08-22-2013 11:03 PM
  3. kal1209's Avatar
    What should I look for? I can't believe I was this lucky. Even when I shake it it doesn't sound like there's any liquid in there.
    08-22-2013 11:13 PM
  4. Golfdriver97's Avatar
    Just the device acting weird. Mostly if the screen acts up or the headphones.
    Deanig_12 and kal1209 like this.
    08-22-2013 11:18 PM
  5. Deanig_12's Avatar
    I wouldnt be too sure on luck as you will have to monitor it as my friend did this then 7 days later her phone fried so she had to get a replacement just keep an eye on it like other people have said
    Sent from my GT-I8190 using AC Forums mobile app
    08-22-2013 11:37 PM
  6. pseudoware's Avatar
    It'll likely be OK, but if your N7 acts up, no use crying over spilled milk. :-D
    Richard Reeves likes this.
    08-23-2013 01:52 AM
  7. Srambo217's Avatar
    That's gonna smell great in a few days
    If it's working then don't sweat it!
    Sent from my Nexus 7 using AC Forums mobile app
    08-23-2013 02:59 AM
  8. bjrosen's Avatar
    No use crying over spilled milk.
    Seriously you might want to spray some contact cleaner into the jack but aside from that I don't think you have to worry, if it's working then you are OK. Milk isn't corrosive so I don't think it will do any long term damage.
    08-23-2013 11:44 AM
  9. YAYTech's Avatar
    be sure to test with headphones.
    08-23-2013 11:50 AM
  10. mak916's Avatar
    Did you put it in some rice?
    08-23-2013 01:40 PM
  11. kal1209's Avatar
    I tested it with headphones and they worked perfectly.
    08-23-2013 06:56 PM
  12. kal1209's Avatar
    No I didn't put it in rice. Could I use a compressed air can?
    08-23-2013 06:57 PM
  13. physioprof's Avatar
    Rice Krispies would be even better.
    08-23-2013 07:28 PM
  14. kal1209's Avatar
    It's been 3 days and I cannot find any obvious problems with my Nexus 7.
    08-25-2013 06:33 PM
  1. Did my first ISIS transaction tonight using the MAXX
    By alee in forum Motorola Droid MAXX
    Last Post: 01-16-2014, 08:32 AM
  2. Mobile hotspot issues and temp workaround
    By dariusf in forum T-Mobile Galaxy S II
    Last Post: 08-27-2013, 11:47 PM
  3. Upgraded to MAXX from GNex -- My Thoughts
    By mblouir in forum Motorola Droid MAXX
    Last Post: 08-26-2013, 09:33 AM
  4. nexus 7
    By Nick Black in forum Google Nexus 7 Tablet (2012)
    Last Post: 08-22-2013, 11:17 PM
  5. No MIFARE NFC Support on Nexus 7 2013?
    By Ranfu in forum Google Nexus 7 Tablet (2013)
    Last Post: 08-22-2013, 08:59 PM
