1. Radeon7000's Avatar
    I just bought a brand new Nexus 7 2013 model and the volume of the speakers at max is noticeably lower than my lumia 820 at max.Is this normal or have I got a defective unit?Thanks for helping
    10-29-2013 04:37 AM
  2. Haalcyon's Avatar
    Good morning.
    Without being able to hear them both and compare them that's challenging for us to say. I've had several Nexus 7's and never had and volume issues. If you've set the volume controls where you want them and the volume is still not where you think it should be you can try exchanging it for another unit but comparing it to a completely different device may not be a good indicator of whether or not there's a problem with its audio.
    10-29-2013 05:13 AM
  3. Radeon7000's Avatar
    For instance the click sound which comes from the speakers when you touch the screen is very low at max volume and I can hear it but its very low.Is it the same with your nexus?
    10-29-2013 05:50 AM
  4. Haalcyon's Avatar
    No, it's quite loud (even annoyingly so) on my 7.
    10-29-2013 06:00 AM
  5. Radeon7000's Avatar
    Could you tell me whether the sound on my tablet is normal on the basis of this video?I know its difficult to check in a video but still.....
    10-29-2013 07:04 AM
  6. gerryp123's Avatar
    Speakers seem loud enough to me (louder than in previous model).
    Make sure volume setting is at highest in Settings and/or Volume Switch.
    Use a player app with a preamp function (like PowerAmp)
    10-29-2013 08:27 AM
  7. Radeon7000's Avatar
    Volume is on max.I will try that player.The only problem which makes me suspect the speakers is that the touch sounds are really low meaning that I can hear them but barely.Also on max volume in vlc media player the movies sound "normal" meaning I can hear them perfectly and I don't feel a need to reduce the volume but thats on max volume.So are my speakers defective?
    10-29-2013 08:40 AM
  8. Jeremy8000's Avatar
    If convenient, go to any retailer nearby who has a N7 on display and compare the two. I'm suspecting its an issue with your unit, as unless mine is just a particularly loud sample I can't imagine someone being disappointed with the output given the size of the device - it's much, much louder than the 2012 model.
    10-29-2013 08:49 AM
  9. Radeon7000's Avatar
    Are the touch sounds too loud with your unit or are they low tone meaning you can barely hear them?
    10-29-2013 08:58 AM
  10. Radeon7000's Avatar
    Guess I will go for an exchange then.Thanks anyway
    10-29-2013 10:38 PM
  1. LTE Band Support and Verizon: Nexus 7 LTE and Nexus 5
    By diesteldorf in forum Google Nexus 5
    Last Post: 11-05-2013, 05:23 PM
  2. Removing suggested email addresses. Help!
    By Jmr674 in forum Samsung Galaxy SIII I9300
    Last Post: 10-30-2013, 04:25 AM
  3. need help with galaxy s3
    By Lizbeth Montes in forum Samsung Galaxy S3
    Last Post: 10-30-2013, 02:04 AM
  4. Replies: 4
    Last Post: 10-29-2013, 10:03 AM
  5. Nexus 7 2013 low volume speakers.Help please!
    By Radeon7000 in forum Google Nexus 7 Tablet (2012)
    Last Post: 10-29-2013, 06:31 AM
