Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By UJ95x
  • 2 Post By Golfdriver97
  • 1 Post By physioprof
    Default Nexus 7: Is this normal battery usage?
    Hey guys
    I'm new to android (and modern technology in general really), so I apologise in advance if this is a stupid question, but is this battery usage normal?
    Screen - 27%
    Tablet idle - 21%
    Android system - 12%
    Chrome - 10%
    Media server - 6%
    Android OS - 5%
    Three processes related to chrome - 10%
    Com.android.systemui - 2%
    What is this mysterious media server? Why is tablet idle so high? And why does chrome and it's processes refuse to stop using battery even after I close out of it completely?
    Thanks a lot again, hopefully this question isn't too insufferable.
  2. #2
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    Default Re: Is this normal battery usage?
    Quote Originally Posted by FlyHighGuy View Post
    Hey guys
    Screen - 27%
    Tablet idle - 21%
    Chrome - 10%
    Media server - 6%
    Android OS - 5%
    Welcome to Android Central
    We're going to need more info. You can upload screenshots from your battery stats. Show how long each of these is running and maybe we can be of more help
    FlyHighGuy likes this.
  3. #3
    Golfdriver97's Avatar
    Posts
    Global Posts
    32,719 Global Posts
    Carrier
    Pure Nexus/Franco Kernel
    Default Re: Nexus 7: Is this normal battery usage?
    Welcome to the forums.
    Based on what you typed, that doesn't seem that bad.
    Does it sit idle? If yes, then that will explain the high OS usage. Media server is a general category for simple things like downloads from Play.
    I do agree with UJ95x. I would also like to see a screen shot of your battery stats and the graph, please.
    From a Sprint Moto X using AC Forums app
    UJ95x and FlyHighGuy like this.
  4. #4
    Media Server also is used for watching videos like on YouTube.
    Sent from my Nexus 7 using AC Forums mobile app
    Thank you guys!
    Well I did eventually figure out how to take a screenshot of my battery usage, but I couldn't figure out how to post the image here from my nexus. I know, I'm a newb. Could someone enlighten me?
  6. #6
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    Thank you guys!
    Are you on the AC app or the AC Forums app?
    Can't be done on the first, but the second one will give you the option to if you open the thread, hit the options in the upper-right hand corner and hit reply. Then do it again to see the option to add attachment or insert URL link to an image
  7. #7
    sk8trix's Avatar
    Posts
    Global Posts
    836 Global Posts
    Carrier
    CM9
    Since 4.3 some processes run in the background more often, what you should be worrying about is how often the device wakes up while the screen is turned off, it it doesnt wake up too much you should be okay with battery. I use my tablet alot even while using LTE I manage to get about 24 hours battery life, and that is playing games,browsin,etc. If youre rooted you can try disabling some apps you don't need as well as maybe using things like greenify and Titanium backup.
  8. #8
    it seems that if you use it for an hour, the battery power will decrease about 10%.
    and you put it on standby, close all the apps, after one night, the batter power will decrease about 3%.
    go check it yourself, if it is in that range, your battery is ok.
  1. Replies: 88
    Last Post: 02-26-2014, 11:07 AM
  2. Replies: 5
    Last Post: 01-22-2014, 07:22 AM
  3. one of my quad core processors is not working
    By simon2008 in forum Samsung Galaxy S3
    Last Post: 01-22-2014, 03:14 AM
  4. Replies: 2
    Last Post: 01-21-2014, 06:57 PM
  5. Replies: 2
    Last Post: 01-21-2014, 05:17 PM
