1. tor toresen's Avatar
    It just happened over night. The fact that it works in Safe Mode makes me think that it has something to do with software, but after doing a factory reset, the problem is still there. I've tried using headphones as well, but still no luck.
    Can anyone help me with this problem?
    Thank you for your time!
    01-23-2014 10:52 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! I know you did a factory reset, but it doesn't hurt to try a system cache partition wipe as well: http://forums.androidcentral.com/goo...tion-wipe.html
    01-23-2014 11:53 AM
  3. tor toresen's Avatar
    It did unfortunately not help :S Could there be any of the standard software that are at fault?
    01-23-2014 12:06 PM
  4. B. Diddy's Avatar
    Sure seems like it. How old is the tablet? I would guess it's still under warranty. You could try contacting Google support here--click on "Contact Us" at the upper right.
    01-23-2014 12:14 PM
  5. tor toresen's Avatar
    I bought it in October so warranty should be fine. Yeah, it seems like I have to contact either Google or Asus because there doesn't seem to be any answer on the internet.
    01-23-2014 12:22 PM
  6. patruns's Avatar
    Did you recent;y install any apps?
    01-23-2014 01:55 PM
  7. B. Diddy's Avatar
    He noted it still seemed to occur even after factory reset, so I'm guessing it's not 3rd party apps ...
    brosko and patruns like this.
    01-23-2014 02:12 PM
  1. Web browsing on Nexus 7 2nd generation battery drain !!
    By iDoc86 in forum Google Nexus 7 Tablet (2013)
    Last Post: 02-07-2014, 06:02 PM
  2. Google Music didn't upload all tracks.
    By Fruz in forum Android 4.4 KitKat
    Last Post: 01-24-2014, 11:48 PM
  3. Can't stream media on S4 after 4.3 update?
    By thegeekkid in forum Samsung Galaxy S4
    Last Post: 01-24-2014, 11:48 AM
  4. Messaging app that uses data AND my number...
    By Effenhimer in forum Verizon Galaxy S III
    Last Post: 01-24-2014, 12:08 AM
  5. Replies: 4
    Last Post: 01-23-2014, 01:46 PM
