Results 1 to 9 of 9
    Default USB Jack in N7 2013 doesn't keep cord in. How do I fix
    This has happened to me on all of my Android phones. The jack in the device gets loose and it's hard to keep the USB cable in. Any solutions? It's frustrating to keep it charging.
  2. #2
  3. #3
    Default Re: USB Jack in N7 2013 doesn't keep cord in. How do I fix
    This is the exact reason I use a Qi wireless charger. Any electronic connector is rated for only so many insertion/extraction cycles. You could try a new charger, where the male USB connector has not worn down yet.
    It didn't get great reviews though
    Sent from my Nexus 7 using Tapatalk
  5. #5
    Considering all of the various manufacturers and configurations (and the fact I have not had issues on over 5 different devices made by 5 different manufacturers) you are probably being a little rough on your devices. Does a new cable help for a while? Those ports are a bit delicate and not anywhere near as robust ans a full size USB port. Add that to the fact that some go one way and some are upside down, if you are not careful bad things happen.
  6. #6
    Quote Originally Posted by sethgoldstein View Post
    Take a look at the Nokia QI chargers, the DT-900 and DT-910. They work well and you can pick one up at your local AT&T store.
  7. #7
    It didn't get any worse reviews that any of the other wireless chargers. Most of those people that gave it bad reviews probably did so because it wouldn't work with a half inch thick case or their device isn't even qi compatible I bet.
    Take it from me, it works great, even through my rather thick folio case that I have on mine. Only thing I don't like is that there is a little bit of heat build up on the charging pas and the back of the device, but that is inherent with wireless charging.
  8. #8
    rjack22's Avatar
    Posts
    Global Posts
    477 Global Posts
    Take a look at the Tylt Vu wireless charger. I love mine. Yeah its a bit pricy but it is well worth it.
    Thanks guys. I didn't think I was being rough with it but who knows.
  1. Replies: 3
    Last Post: 09-08-2014, 03:53 PM
  2. Email program won't download emails newer than 12/27/2013!
    By CRUZR in forum AT&T Samsung Galaxy Note 3
    Last Post: 03-01-2014, 09:25 PM
  3. How to retrieve all my Lost System Apps
    By huntress7287 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 01-31-2014, 03:17 AM
  4. Help could u tell me how to open it
    By stacey robinson in forum Samsung Galaxy Ace
    Last Post: 01-30-2014, 05:57 AM
  5. Wallpaper keeps changing
    By russel5150 in forum Motorola Droid MAXX
    Last Post: 01-30-2014, 02:18 AM
