1. Enricke Kee's Avatar
    When I plug in any speakers or headphones in my Nexus 7 (2013), only the left channel works fine but the right channel won't have any sound unless if I hold the headphone jack. Do you guys know how to solve this?
    01-31-2014 08:53 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Could be the jack or your headphone's plug. First, have you tried any other headphones? If they're fine, then the problem is probably with the first headphone's plug. If all headphones have the same problem, then I'd focus on the jack. Make sure there isn't any debris in the jack by using a damp toothpick to root around, or a can of compressed air to blow it out. If that still doesn't work, then you may need to send it in for repair, if the jack is messed up.
    01-31-2014 09:26 PM
  3. PowrDroid's Avatar
    Sounds like lint or other debris is in the headphone jack area. B.Diddly's advice has worked for me when I had this problem with my phone.
    Sent from my Nexus 7 using Tapatalk
    B. Diddy and bankshotaholic like this.
    02-01-2014 11:25 AM
  4. Liger-96's Avatar
    I'm having the same problem, but I have to apply direct pressure to the headphone jack to get sound. I've tried multiple headphones too.
    05-26-2014 08:06 AM
  5. B. Diddy's Avatar
    Welcome to Android Central! Is the plug all the way in? You should feel or hear a click when it's fully seated.
    Posted via Android Central App.
    Please excuse any typos or autocorrect derps.
    Laura Knotek likes this.
    05-26-2014 07:36 PM
  6. bankshotaholic's Avatar
    Hey bro, grab a can of compressed air, place it very close to, but not inside of the headphone jack and press the canister button for about 5 seconds. The goal is to remove the dust, lint or whatever is gunking up the connection. Werked for me!
    11-03-2016 08:29 PM
  7. bankshotaholic's Avatar
    Mr. B Diddy is right. Bro, grab a can of compressed air, place it very close to, but not inside of the headphone jack and press the canister button for about 5 seconds. The goal is to remove the dust, lint or whatever is gunking up the connection. Werked for me!
    11-03-2016 08:32 PM
  1. Mobile data problems
    By Tiago Baldissara in forum Samsung Galaxy S4
    Last Post: 04-16-2014, 05:40 AM
  2. Music Player(s) with Headphones
    By Blaxer4 in forum HTC One M7
    Last Post: 02-06-2014, 05:18 PM
  3. Will the Nexus 7 2nd gen 2013 work on my router?
    By ishimura in forum Google Nexus 7 Tablet (2013)
    Last Post: 02-04-2014, 03:53 PM
  4. Nexus 7 (2012) in a Bad Way
    By shepherd_wood in forum Google Nexus 7 Tablet (2012)
    Last Post: 02-04-2014, 10:08 AM
  5. Replies: 0
    Last Post: 01-31-2014, 04:24 PM
