Results 1 to 11 of 11
    Default inconsistent wireless charging notification sound
    Does anyone who uses wireless charging notice that maybe 25% of the time when you put the n7 on the WC pad it fails to make the charging started" sound. Most of the time it works, but it is not very consistent. I have noticed that when it doesn't make the sound, it IS still charging (providing it is placed on the pad correctly) , so I guess it really doesn't affect the functionality, but it would be nice if it made the sound every time to assure me of a positive connection with the WC unit.
    Anybody have any input on this?
  2. #2
    Chex313's Avatar
    Posts
    Global Posts
    662 Global Posts
    Carrier
    6.0 Marshmallow
    Default Re: inconsistent wireless charging notification sound
    Quote Originally Posted by brosko View Post
    Does anyone who uses wireless charging notice that maybe 25% of the time when you put the n7 on the WC pad it fails to make the ”charging started" sound. Most of the time it works, but it is not very consistent. I have noticed that when it doesn't make the sound, it IS still charging (providing it is placed on the pad correctly) , so I guess it really doesn't affect the functionality, but it would be nice if it made the sound every time to assure me of a positive connection with the WC unit.
    It's inconsistent on my Nexus 5 as well. I don't mind, I would rather not wake my wife if she is sleeping. I just make sure the charging notification(Light Flow) comes on.
    brosko likes this.
    Thanks for reply. I don't mind ethier. I was just more curious than anything I guess. I kinda like the sound only because I have a folio case on my n7 and when I put it on to charge I obviously do so with cover closed, so ant visual confirmation will do me no good. That's why sound is nice IMO.
  4. #4
    Inconsistent here too.
    N7 2013
    Still charges though
    B
    brosko likes this.
    While on the subject of wireless charging, do you know what an acceptable battery temperature would be when charging. I have noticed that both the back of the device and the WC pad get really warm after charging for 15 or so minutes. I just took mine off the wireless charger and the battery temp was at 93 degrees Fahrenheit. Is this normal?
  6. #6
    I find it's the QI charger that creates most of the heat. So what I do is put my N7 on the night table face down and put the QI charger face down on top of my N7.
    So everything is upside down.
    Try it and let us know what your temperature readings are afterwards.
    B
    Quote Originally Posted by Buffster5505 View Post
    B
    Good idea. I will try it and report back. Also I just noticed that it seems perfect placement is key, as when I took care to perfectly place my nexus dead center on the pad the battery temp stayed in the mid 80's. It seems to struggle charging when its not centered as well thus generating more heat?
  8. #8
    Chex313's Avatar
    Posts
    Global Posts
    662 Global Posts
    Carrier
    6.0 Marshmallow
    Well I can't compare to your N7(I have the old one) but my N5 generates no heat at all on this charger. Amazon.com: Lerway Wireless Qi Power Charger Pad for Lumia920 HTC 8X S4 S3 Note II (Black): Cell Phones & Accessories and gets slightly warm on a dual energizer charger. Just guessing I would say in the 100F range.
    They do charge faster at first then slow the charge rate and seem to cool as time passes. When you get up near 80% does it cool then or is it still hot? If its not cooling off by then. I would be concerned. 98F Is not that hot for a battery.
    It gets progressively cooler as it nears a full charge. I guess it's all good.
  10. #10
    I would not worry about temps around 100 degrees. Your phone is getting that hot if you put it in your pocket. More if you move at all or go out in the sun.
  11. Thread Author  Thread Author    #11
    Quote Originally Posted by jerrykur View Post
    jerrykur, does your n7 have the inconsistent charging sound when put on the charging pad that I described in my first post?
  1. Charging issues
    By kelleygirlmma in forum Samsung Galaxy Tab
    Last Post: 02-19-2014, 11:48 PM
  2. Pop up SMS notifications that stay on screen
    By Gastrodoc in forum General News & Discussion
    Last Post: 02-02-2014, 11:13 PM
  3. Not fully charging?
    By ansa82 in forum Verizon Samsung Galaxy Note 3
    Last Post: 02-02-2014, 02:58 PM
  4. System Sounds Muted
    By peter storm in forum Android 4.4 KitKat
    Last Post: 02-02-2014, 01:36 AM
  5. how to get lock screen notifications
    By ahawkua in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 02-01-2014, 08:15 PM
