Results 1 to 7 of 7
    gerryp123's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Nexus 7: Battery Problem?
    After 6 months of predictable battery performance my N7 (2013) suddenly requires more frequent charging. Apps at start-up are as expected. App power usage seems normal. Wifi, gps, bluetooth usage are as they always have been. Also, start-up (from power-off) seems slower.
    Perhaps there is something running in the background that I cannot see. Is there a tool or procedure that can determine this? Perhaps the battery itself has degraded over time
    Any suggestions to track this down?
  2. #2
    Jon_Doh's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Battery Problem?
    You can try a battery monitor like GSAM to tell you what's using up the battery. Then, you might want to install Greenify to hibernate those misbehaving apps.
  3. #3
    Ntchwaidumela's Avatar
    Posts
    Global Posts
    1,948 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I don't believe your battery has degraded in such a short time. There is something running in the background even while the device is idle. A battery monitor will tell you what it is. Also, if you're not going to use it for more than a few minutes, turn it off rather than putting it to sleep. Apps are still running during sleep mode.
    Sent from my SM-N900P using AC Forums mobile app
    gerryp123's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Ntchwaidumela
    I think you are correct - there is something running in the background.
    Any advice on how to find it (in an unrooted tablet) and how to minimize its drain?
  5. #5
    Posts
    Global Posts
    1,948 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    You can go into Settings>General>App Manager, then scroll to Running then stop any app you don't need to run.
    Sent from my SM-N900P using Tapatalk
  6. #6
    Victor R's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Just curious, I installed GSAM Manager and it shows me Android Kernel using 70% of the battery. Is that normal? I have not used it in 3 days and it was completely dead. I have screen shots if anybody would like to see them
  7. #7
    joe_fresh's Avatar
    Posts
    Global Posts
    1,634 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    HTC One stock
  1. LG G2: Microphone problem
    By Jayme Koerselman in forum LG G2
    Last Post: 09-07-2016, 03:28 PM
  2. Battery Halved after Restart
    By James Fawkes in forum Moto G (2013)
    Last Post: 02-17-2014, 04:07 PM
  3. Queries on my battery drainage
    By UVERtainment in forum Samsung Galaxy Note 2
    Last Post: 02-17-2014, 06:31 AM
  4. s4 battery
    By armin80 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 02-17-2014, 12:41 AM
  5. Problems sending e-mail
    By cb2367 in forum Sprint Galaxy S3
    Last Post: 02-16-2014, 11:55 PM
