1. gerryp123's Avatar
    I've read that every 60 days or so it's a good idea to let the Nexus battery completely discharge before recharging it. Correct?
    What happens to Nexus hardware, software, and apps when the battery runs down to zero? Auto shut-down? Any harm done?
    02-23-2014 09:03 PM
  2. B. Diddy's Avatar
    I'm sure people will still debate this, but from what I know, there is no need to completely discharge the battery in any modern device to keep it healthy. It's generally a bad idea to let your battery get close to true zero anyway, because if it completely discharges, the battery is irreversibly dead. Devices will auto-shutdown before it gets to true zero, but then you'd want to get it on a charger before too much time passes.
    Ntchwaidumela likes this.
    02-23-2014 09:10 PM
  3. patruns's Avatar
    B. Diddy is correct. Completely discharging a lithium battery will kill it. There is no need to try and run it down as far as it will let you. Just continue to charge as needed.
    B. Diddy and Ntchwaidumela like this.
    02-24-2014 09:12 AM
  4. brosko's Avatar
    That's exactly it, just charge when you start getting low, between maybe 10 & 30%
    02-24-2014 06:15 PM
  5. jolphil's Avatar
    Heres another link to help explain Lithium batteries..
    Charging Lithium-Ion Batteries – Battery University
    Goodluck
    02-25-2014 07:32 AM
  6. gerryp123's Avatar
    Interesting paper.
    It says that for most effective charge, battery should be "off" when re-charging. I generally have my N7 in a "sleep" mode when recharging so that I hear notification when charging reaches 100%. I guess the small current drain is acceptable.
    02-25-2014 09:03 AM
  7. YAYTech's Avatar
    But no need to wait that long either. If it's at 90% and it's a good time to plug in, go for it. I simply charge my devices every night, no matter what their charge level is. I don't have to think about battery life, because I rarely use my phone or tablet enough in one day to run it out, so the "charge every night" habit means everything's always working. I'd say just try to keep from running it out completely too often, and don't worry about it beyond that.
    02-25-2014 10:58 AM
  8. jolphil's Avatar
    I think the experts in that article suggest 0 drain current during charging is so the Battery monitor circuit can correctly know when it reaches 100%
    It did state that if overcharged , some battery stress is possible..
    I always shut my N7 off when charging either with the Micro port or the Qi charger. I generally will recharge when it gets somewhere below 50% but if I know I will be using it the
    next day I will charge even if it is 85% or so..But that's just me..Heat is also a big problem thus I do not try to let it fully discharge to minimise heating.
    Goodluck to you
    jolphil
    02-25-2014 02:35 PM
  1. Nexus 7: Severe battery drain while device is asleep
    By zackmack7 in forum Google Nexus 7 Tablet (2013)
    Last Post: 12-31-2016, 05:49 AM
  2. Replies: 35
    Last Post: 04-01-2015, 09:00 AM
  3. Whatsapp and draining battery
    By LH79 in forum Samsung Galaxy SIII I9300
    Last Post: 09-08-2014, 04:24 PM
  4. My Galaxy Note 3 N9005 screen went all black and battery gets really hot
    By Endre Ruttkay in forum Samsung Galaxy Note 3
    Last Post: 07-03-2014, 03:03 AM
  5. Galaxy Tab Pro 8.4: battery life was awesome right out the box...
    By htc evo 4g in forum Samsung Galaxy Tab Pro 8.4
    Last Post: 03-09-2014, 08:56 AM
