1. Gauhar Mahmood Azeem's Avatar
    Since a few days my tablet has been burning battery during it's sleep. Here is a screen shot of when I was asleep and tablet on air plane mode and you can see battery dropping from 90 to 56 percent over time without any reason. Can anyone guide me as to why this is happening and a solution?
    Sent from my Nexus 7 using Tapatalk
    02-28-2014 09:53 PM
  2. jolphil's Avatar
    Wow, that appears to be a severe drain..I can only suggest that you try going into the safe mode to shut off all non system apps..That may give you a clue.
    Goodluck
    03-01-2014 05:59 PM
  3. B. Diddy's Avatar
    It'd be helpful to see the breakdown of battery use by app or service as well.
    03-01-2014 09:02 PM
  4. Gauhar Mahmood Azeem's Avatar
    The cache partition wipe has solved the issue dramatically, for now
    B. Diddy likes this.
    03-03-2014 10:15 AM
  5. cybernutte's Avatar
    What is a cache partition wipe?
    03-03-2014 09:50 PM
  6. B. Diddy's Avatar
    http://forums.androidcentral.com/goo...tion-wipe.html
    cybernutte likes this.
    03-03-2014 10:40 PM
  7. cybernutte's Avatar
    Thanks very much, B. Diddy, for the link to your clear and well-illustrated instructions.
    03-04-2014 03:44 PM
  8. zackmack7's Avatar
    I was having the same issue. I tried a cache partition as well but it didn't help me too much. My battery just recently started acting normal.
    See my below thread
    http://forums.androidcentral.com/goo...ce-asleep.html
    03-06-2014 01:54 PM
  9. lingcod777's Avatar
    I uninstalled Skype and solved my mystery battery drain while the Tablet was inactive and supposedly asleep. I was on having 1 day (or less) standby and am now at 50% on day 2 (had some use). Complements to a XDA thread.
    03-06-2014 10:11 PM
  10. B. Diddy's Avatar
    Hmm. A Microsoft conspiracy to make Android users want to switch to Windows tablets?
    03-06-2014 10:36 PM
  11. jerrykur's Avatar
    More info on the skype and other applications in 4.4.2 causing high battery drain and overheating. It looks like there is bug in the camera software. Maybe this is the root cause of the crashes and reboots some people have seen when using the Nexus camera. There is a fix from Google coming. If you are not on a Nexus device, then you still may have the issue, but the fix has to come from the device's manufacturer.
    KitKat giving you battery drain problems? Try uninstalling Skype, says Google as it prepares a fix | ZDNet
    B. Diddy and brosko like this.
    03-07-2014 10:00 AM
  12. avatarx0's Avatar
    I had the same problem and fixed it by uninstalling Skype... I'm using android 4.3... WTF Microsoft!
    03-15-2014 09:11 PM
  1. Motorola - What's in their future?
    By Murph5150 in forum Verizon
    Last Post: 03-11-2014, 03:46 PM
  2. Sell Note 2 now with 4.3 or worth more if 4.4 in a month(ish)
    By Matt Behnken in forum AT&T Galaxy Note 2
    Last Post: 03-02-2014, 11:57 AM
  3. Same battery consumption issues from jellybean still exists in kitkat
    By LordAndroid in forum AT&T Samsung Galaxy S4
    Last Post: 02-28-2014, 10:34 PM
  4. Does having "recently opened apps" open shorten the battery life?
    By skstrials in forum General Help and How To
    Last Post: 02-28-2014, 02:16 PM
  5. Wife has s3 and is able to update in july
    By jlost in forum Samsung Galaxy S5
    Last Post: 02-28-2014, 12:47 PM
