Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By jerrykur
    Eaton Scrapple's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Nexus 7: Strange Battery Graph, wonder if it suggests problem?
    Apparently, my Nexus 7 2013 can briefly RECHARGE ITSELF...note the small spikes where the battery level INCREASES while sleeping! Aliens, spirits or ???
    Seriously I wonder if there isn't some problem with my device...battery life is all over the place. Sometimes I can watch it drain as I use it. It's all stock stuff.
  2. #2
    skyrockett's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    4.1.2 stock JB
    Default Re: Strange Battery Graph, wonder if it suggests problem?
    known bug... N7 got some sort of software problem that affects battery life.
  3. #3
    jerrykur's Avatar
    Posts
    Global Posts
    1,232 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The calculation of available battery is an estimate effected by a number of conditions. It is not a extremely precise measurement.
    You can test this for yourself with a rechargeable battery. Charge the battery to full. Remove the battery from the charger and wait a couple of minutes. Re-insert the battery. It will take a few seconds or minutes for the charger's circuity to register that the battery is already full and shutdown.
    The bottom line is look at the general trend of the line and forget the minor spikes and dips.
    Ntchwaidumela likes this.
  1. Reception problems with the Verizon Note 3
    By aspenedelen in forum Verizon Samsung Galaxy Note 3
    Last Post: 03-11-2014, 05:22 PM
  2. Keep Nexus 5 or return it and wait for S5?
    By davekr in forum Samsung Galaxy S5
    Last Post: 03-10-2014, 03:18 PM
  3. Reception problems with the N3
    Last Post: 03-10-2014, 12:18 PM
  4. Phone signal and it's effect on battery life
    By dpham00 in forum Samsung Galaxy Note 3
    Last Post: 03-10-2014, 11:18 AM
