1. MIMS3108's Avatar
    I was losing battery power even when charging so changed the battery. I cant turn the nexus on so don't know if it is charging or not.
    tried holding volume button and power on /off button but nothing happens, please can anyone help me before I launch it across the room
    04-03-2014 06:27 AM
  2. Kelly Burby's Avatar
    well, there might be two reason one might be there may be some problem with the charger or your battery might be worn out !! But still I would stress you on checking the charger try pulgging it to another charger.
    MIMS3108 likes this.
    04-03-2014 06:36 AM
  3. MIMS3108's Avatar
    its a new battery and the charger works as I have used it this morning on my phone
    04-03-2014 06:37 AM
  4. Kelly Burby's Avatar
    well, in this case i think you need to go to the nearest dealer, it looks like the problem is in the hardware their is a charging IC inside the device, it might been worn out.
    04-03-2014 06:43 AM
  5. MIMS3108's Avatar
    really... are they expensive to buy and fit?
    ok I have a couple of friends that maybe able to help me out. Don't want to spend too much money on it as I can get a new one for 179 and have already spend 26
    04-03-2014 06:49 AM
  6. jerrykur's Avatar
    Are you using the charger and cable that came with the Nexus 7? Phone chargers do not put out enough Amps to charge the Nexus 7 in a reasonable amount of time.
    04-03-2014 01:03 PM
  7. preppystud's Avatar
    chat with asus people online, they will probably ask you to send it to them for a repair.
    04-04-2014 05:23 PM
  1. Replies: 19
    Last Post: 06-02-2014, 12:05 AM
  2. fully working with all the bands on AT&T
    By usguyver in forum HTC One M8
    Last Post: 04-04-2014, 02:45 AM
  3. ●help● adds pop up on homepage and in all apps
    By Seb Wood in forum Samsung Galaxy Note 3
    Last Post: 04-03-2014, 04:51 PM
  4. how many speakers nexus 5 have? and how many of them will work
    By Kochumoidu Maharoof in forum Nexus 5 Rooting, ROMs, & Hacks
    Last Post: 04-03-2014, 04:53 AM
