1. theotheronetwothree's Avatar
    Got this. Searched the forums and apparently the only way to get rid of it is through a factory reset?
    Anyone else figured out another way? I noticed it started happening when I downloaded Instagram and another camera app.
    Also, when you do a factory reset, does it get rid of the preinstalled apps. For example, will the camera and voice recorder still be there (although I know that the files will be deleted)?
    04-28-2014 11:50 PM
  2. mchockeyvette27's Avatar
    Have you tried to uninstall those apps and do a hard reboot?
    And factory reset will revert your phone back to exactly how it was when you got the phone. All preinstalled apps will be there.
    Sent from my HTC One_M8 using Tapatalk
    04-28-2014 11:55 PM
  3. theotheronetwothree's Avatar
    I got rid of the apps.
    ETA: just did a hard reset, still there.
    04-29-2014 12:06 AM
  4. mchockeyvette27's Avatar
    I'm not sure of any other ways around it, so if a reset is something you wanna do I say that's the best way to get rid of it.
    04-29-2014 12:44 AM
  5. theotheronetwothree's Avatar
    Just did a factory reset. Fixed the problem. But I'm still wondering where the "mm-qcamera-daemon" came from. Hope google is aware of the problem...
    04-29-2014 01:27 AM
  6. mchockeyvette27's Avatar
    I do in fact believe they are aware of this problem and it comes from downloading other camera apps. I remember reading about it somewhere but not 100% sure.
    04-29-2014 01:29 AM
  7. reepS's Avatar
    Mine came from snapchat
    Sent from my Nexus 5 using Tapatalk
    05-01-2014 09:38 PM
  8. jerrykur's Avatar
    It is a known issue. Just google "mm-qcamera-daemon"
    05-02-2014 04:10 PM
  9. George S2's Avatar
    I heard that Google created the bug in order to force users to install a system update that has received a lot of complaints. So many people were complaining about Google's latest system update (adding more advertisements, draining battery life, defaulting paid apps to turn on) that they were turning off their auto update. Google couldn't allow that, so they created this bug where the only fix is to install their update or the alternative is a phone that drains battery so fast that the phone overheats. Proof: If this bug were created by anyone outside of Google, the first thing they would have done was identify the culprit and told users not to download the app. Instead, the fix they are pushing is a factory reset, to again force out their latest system upgrade, as well as to reinstall all those nuisance pre-installed apps that everyone immediately deletes.
    06-08-2015 09:26 PM
  1. How's your note 3 battery life?
    By Isc73 in forum General News & Discussion
    Last Post: 05-02-2014, 06:15 PM
  2. Replies: 2
    Last Post: 04-28-2014, 08:45 PM
  3. Launch time buyers, how is your battery holding up?
    By Darth Mo in forum HTC One M7
    Last Post: 04-28-2014, 07:59 PM
  4. Battery life
    By AJ Banks in forum Android Apps
    Last Post: 04-28-2014, 06:56 PM
  5. MMS
    By Courtney Urbanski in forum LG Optimus Series
    Last Post: 04-28-2014, 01:03 PM
