Hi,
so I noticed that my battery became worse, it has some task running called "tes.antimalware" that runs in the background, and I can't turn it off, also tablet idle is sucking the battery. I haven't used it and it discharged from 26 percent to 7 percent in airplane mode in about 6 hours. How can I disable that "tes.antimalware" task? I'm running CM11, I had a wonderful battery life with it.
