- 01-02-2013, 02:19 PM
Thread Author #1
OTG Cable question (not on the cable)
I've been reading that the OTG cable will allow me to utilize (let's say) a 16GB memory stick to add more space to my tablet. I insert the OTG cable and a memory stick and away I go.
But after reading a lot;
1) Do I have to root my device in order for this to utilize the cable?
2) Do only certain programs acknowledge the cable\memory? Does it have to be a program that has that code written into it?
I'm just looking at the extra storage; ie: reading materials, movies, music. But if I start storing pictures or documents do I run into problems? - 01-02-2013, 02:45 PM #2a.k.a. RyZR from HoFo
Motorola DROID Bionic (6.7.246.XT865.Verizon.en.US, Ice Cream Sandwich 4.0.4)
Google Nexus 7 (JDQ39, Jelly Bean 4.2.2)
What other devices have I had? Here's my phone timeline.
Support your favorite Android app and game developers. Pay for apps! And don't block ads! - 01-02-2013, 05:26 PM #3
Re: OTG Cable question (not on the cable)
Unrooted = you use Nexus Media Importer app to do read-only access to certain permitted file types, generally media, that can be routed (piped) to another application from within NMI.
Say you want to play a movie file of .AVI format - click and play -> tell NMI to play that with MXplayer and off it goes...
Many file extensions are NOT included in NMI's allowable list but most media types are. Any other app on the Nexus 7 will NOT see the attached storage !
Rooted = you mount the memory with Stickmount and use it pretty much as the normal with a few exceptions, like certain apps will not run from stickmounted storage.
All file types, all apps, few restrictions and free.
follow ? - 01-06-2013, 02:58 PM #4
- 01-10-2013, 02:58 AM #5
I was using Nexus Media Importer, and it does exactly what is described in it's write up. I wanted to be able to save to the external memory device so I decided to root my N7 and install stick mount.
I can now download and save files to the USB device, and it is much easier to copy files to the internal storage as you only need to use a file manager to move things around.
Another advantage of gaining root access is that you can install an ad blocker, which means no more annoying ads when you install some of the free apps. - 01-11-2013, 01:11 AM #6
Bionic will not start / Big Battery with Question Mark on the screen
By gwhizkids in forum Droid BionicReplies: 3Last Post: 12-31-2012, 03:52 PM -
Web browser feature wanted, choose mobile or not on the fly
By Galane in forum Android ApplicationsReplies: 6Last Post: 08-23-2011, 07:22 PM -
A Question/opinion On the 3.1 Update Rollout
By PAC757 in forum Acer Iconia A500Replies: 10Last Post: 07-11-2011, 09:05 PM -
16 GB Memory Question - not about the microSD
By allyn274 in forum T-Mobile Nexus SReplies: 10Last Post: 12-08-2010, 03:03 PM -
Must-have apps that are NOT on the Market?
By whitenack in forum Market HelpReplies: 9Last Post: 06-27-2010, 04:31 PM
Reply
