"Authentication Problem" when trying to connect?
whimsy84
3
I have a d-link N300 DIR-615 router.
when I try to connect to the network: (signal strength: excellent, security: WPA PSK) it just says "Authentication Problem".
I tried setting it to only g/ and only n/ in the wireless settings but had no success.
Any suggestions or feedback would be greatly appreciated. Thank you!:'(
I did indeed. I triple-checked!
Out of curiosity I checked the wi-fi security settings to none (just for a second) to see if it would connect & it connected immediately. Of course I don't want to browse w/ my pants down so to speak so I'm back to being offline. smh.
FDR wifi fix works for me. I get ur issue once month ....netgear router....for past year using cm9 on HP touchpad .....try it out
So it turned out to be because I didn't have WPA enabled on the router. Problem solved. Thank you for the link tomen.
I have just received a Nexus 7 and am getting the same message "authentication problem" trying to connect for the first time. I put in an incorrect password and cannot bring it back to factory status as each time I try, the screen locks and I can get no further than the android lying on its back. Please help a novice!
hello Dear,
I have Q mobile ant it has wireless when I want connect to WLAN it give ( authentication problem )
signal stength is Excellent
link speed Mbps
security WPA PSK
Pleas give me information about it
thanks
hey can someone help me out i have a visual land tablet 9' and i took it to japan trying to connect to wifi using a buffalo wireless router and its not connecting it keeps saying authentication problem can some tel me how to solve this problem thanks
I have a android tablet and I am trying to connect to the internet but it keeps on coming up with authenticion problem and I am not really good with technology so if anyone out there can help me then that would be appreciated kindregaurds Mia
same here but i cant figure out what it is . when i go round friends and i use there wifi im fine and it works like a dream just whenever im at home it never works.:confused:
Re: "Authentication Problem" when trying to connect? to the wifi network
:'( hello out there, i don't know if anybody can help me with my android phone i tried connecting to the WiFi network but what i keep getting back is the authentication problem:confused:i really need your help, i really need to chat with my people. Thanks
I'm trying to connect my phone to wifi and keep getting "authentication problem". What does this mean and how do I fix it.
My problem was my home connection. Here's how I fixed it...... Turn power off all devices (I had three that I was trying to connect). Power off your router. Mine has no power button so I unplugged it. Wait about 60 seconds. Then turn everything back on. Everything connected! Hope it solves your connection problem!
I purchased new xiaomimi4 and trying to connect internet but it says WPA2/WPS securied how i can connect my mobile phone
First thing to try at least is reset both your phone, router and whatever else connected to the internet. If its an IP conflict that usually solves it
Lelix2603
