- 10-21-2012, 02:04 PM #51
- 11-09-2012, 01:37 PM #52
Re: Does anyone have WIFI problem like I do on nexus 7?
I had a problem with my nexus, First time I connected through my home wifi everything went well
I was thrilled! So I turned it of and wend to bed. The next day when I started
The tablet I saw the wireless 4 bars but the triangle on the upper right corner was gray.. I search on the internet for a solution but no luck!!
But when I turn on my laptop BOOM FULL INTERNET SIGNAL!! So what happened? Just that my nexus saw my laptop as a hot spot. So I changed my wifi settinings from DHCP to Static. Go to IP Address and change it.. :-) - 11-14-2012, 07:54 AM #53
- 11-17-2012, 04:36 AM #54
- 12-02-2012, 04:20 PM #55
- 12-12-2012, 03:00 PM #56
- 12-26-2012, 01:06 AM #57
Hey what's up.
So my suggestion may be the most obvious answer but the same thing just happened to me today after I reset my phone to factory settings. I did not properly input capitol letters in WIFI authentication password where I had them. As soon as I re-entered password with proper capitols, it connected immediately. So check if you missed some capitols.
I hope this helps.
Terry - 12-26-2012, 02:03 PM #58
- 12-26-2012, 03:13 PM #59
- 02-04-2013, 08:30 PM #60
Reply
