Results 1 to 16 of 16
- 10-31-2012, 03:05 PM
Thread Author #1
Wireless does not auto reconnect?
Hi,
My home wireless connection is working fine with the Nexus 7 but whenever my router gets switched off the Nexus does not automatically reconnect to it when the router is powered back on.
I have to go into settings -> Wi-Fi -> Click on my wireless network -> Click connect
How can I set it up so that it automatically reconnects when my wireless connection is available?
Thanks. - 10-31-2012, 03:11 PM #2
Re: Wireless does not auto reconnect?
When you go into to your Settings and hit Wi-Fi do you see your wireless network and a list of other networks you have connected to in the past? What type of security do you have on the Wi-Fi? I go to few places and most of the time it connects to my N7 automatically.
- 10-31-2012, 03:58 PM
Thread Author #3
- 10-31-2012, 04:05 PM #4
forget network and connect again
- 10-31-2012, 04:23 PM
Thread Author #5
- 10-31-2012, 05:10 PM #6
- 11-01-2012, 04:52 PM
Thread Author #7
- 11-06-2012, 01:09 PM
Thread Author #8
- 11-06-2012, 03:50 PM #9
Sometimes changing router or security settings will help. Also if you turn your N7 off then on does it connect? Are there any other saved routers in range?
Sent from my Nexus 7 using Android Central Forums - 11-11-2012, 05:38 PM
Thread Author #10
- 11-11-2012, 08:58 PM #11
- Why turn your router off? I'd leave it on.
- Dont' use WPA, it's an early standard, set it to WPA2, with AES encryption.
- If you have regular power outages, put the router on an affordable UPS. A small one will power a router for hours.
Sent by accident, not using the Android Central app
Nexus 4 (Mako), Amaze 4G on T-Mobile. Nexus 7 16GB. Google Chromebook (2012 Samsung 16gb). Next stop, a Google flush toilet.
Did I solve your problem? Hit the Thanks button. Was I just a nuisance? Sorry, can't bat .400 every day. - 11-16-2012, 03:52 PM
Thread Author #12
We are all away from the house for large parts of the day and Electricity prices are going up another 20% in the UK so I would rather only have the router on when I need it.
Unfortunately there is no option for WPA2 on the router.
I guess I will just have to accept it is a "bug" with the Nexus 7 and live with it. Just don't like being told by the wife that I should have bought the IPad Mini .... - 11-16-2012, 04:36 PM #13
If your router doesn't offer WPA2, you've got an ANTIQUE. Go see if you can flash it with dd-WRT, an open source router firmware project that introduces way cool features that the routers' manufacturers didn't enable in their software (but the router hardware supports handily). Hint: you can schedule the radio to turn off when you're not home.
Or ... you need a newer router with some power management features.Sent by accident, not using the Android Central app
Did I solve your problem? Hit the Thanks button. Was I just a nuisance? Sorry, can't bat .400 every day. - 11-16-2012, 04:53 PM #14
Does the Nexus 7 have a native setting that shuts off wi-fi when it goes to sleep?
Nexus running .............
Coming from a 2 1/2 year old BB Tour
- 11-16-2012, 05:36 PM #15Sent by accident, not using the Android Central app
Did I solve your problem? Hit the Thanks button. Was I just a nuisance? Sorry, can't bat .400 every day. - 11-16-2012, 05:40 PM #16Nexus running .............
S3 Bluetooth Does NOT Auto Connect to Car
By FishMeetFish in forum Samsung Galaxy S3Replies: 130Last Post: 04-17-2013, 01:30 PM -
WiFi not auto reconnecting after 3.2 update?
By jcarson13 in forum Samsung Galaxy Tab 10-inchReplies: 4Last Post: 02-10-2012, 11:54 AM -
I got my Nexus One last night, but the USB cable it came with does not fit!!
By Shinwei in forum Google / HTC Nexus OneReplies: 4Last Post: 01-08-2010, 10:41 AM -
Wifi does not work
By alphabets in forum Motorola DroidReplies: 7Last Post: 01-04-2010, 09:50 AM -
Better Keyboard Issues - unresponsive or does not type?
By jdkluck in forum Motorola DroidReplies: 14Last Post: 11-08-2009, 11:00 PM
Reply
