I purchased data plan, but can't figure out how to connect to 3G. :( Have turned off WiFi. Nothing in user guide. Must e a simple setting but I can't find it. Device is new N7 tab with 3G.
Printable View
Are you sure it's the 3g version?
Sent from my RAZR MAXXIMUS ;)
There should be a Mobile Data setting under Settings/Wireless & Networks/more. Also, there's probably a shortcut when you swipe down from the top right (Quick Settings). I don't have the 3G version, so I'm not entirely sure.
I have the 3g version and once I set up and activated the SIM, per the included instructions, it automatically connected to 3g when outside of a Wi-Fi network. You should have an instruction card with the included SIM shipped with the device.
did you insert the sim?Quote:
Originally Posted by Karen Nichols [Only registered and activated users can see links. Click Here To Register...]
