Will the nexus 7 from US work in the UK?
i'm looking to buy the new Nexus 7 32G wifi + 3G but the Google play store has sold out. i have been looking around some sites but all seller are from the US would the tablet still be compatible over here in the UK? e.g. the Google store and if i was to go onto a UK network such as three, T-mobile would i still be able to use 3G ? please help, would be much appreciated. :D
Re: Will the nexus 7 from US work in the UK?
if your carrier supports GSM it will work. Over 200 providers worldwide work with it
would i be limited on the google play store though? as i think some things are US exclusive.
Yes you would be limited on the market to UK. They are the same models sent to UK or US .There is an app that you can use called tunnel bear to make it act like its in the us but I don't know if that works on playstore. And returning may be a Hassl if you have to send it back to US as there seems to be a few that have issues but 32 GB should be better idk I have 16
