So I was applying my nexus 7 wet screen protector and for some reason it seems some water has leaked under my screen causing a hazy effect. After some research I found this is called the Maura effect. How do I know if any of my nexus 7 water sensors have been tripped? Water should not have come under the screen I used a minimum amount. Will Asus cover this?
Thank you
