Results 1 to 4 of 4
    Default Odd battery issue
    Hey all, my wife's Nexus 7 is doing something odd, she didn't use it for a few days do left it on charge. Took it off and after 2 hours the battery dropped to 0% and stayed that way until she noticed it 5 hours later. The status bar icon registers when its on charge but the battery app says 0% Unknown. Have reset it, done a "fastboot erase cache" and even completely run flashed the stock ROM.
    For now I've told her to use it as normal until the battery dies and see what happens when she charges it. Any theories aside from a duff device?
  2. #2
    Default Re: Odd battery issue
    sorry i dont know how to help with that..
    BUT...
    my nexus went on 7% last night, i had to turn it off and charge it over night, and when i woke up, and turned it on, it just turned off again! and i wasnt on it for 11 hours... so does anyone know why, when i turn it on, it hasnt charged and then it turns off again?? thanks (:
  3. #3
    I am experiencing almost the same problem with the exception that I show the percentage of the battery to whatever it is but the screen consumption shows 55% even though the brightness is set to its lowest level. Once plugged it shows as charging with 80% or so battery and as soon as you unplug it goes down to like 16% percent. I have done a factory reset, took it to ATT and had them flash the phone and gave me a new battery and I am still having the same problem. Battery life is garbage for some reason. I have a second SGS3 which is working fine. Hopefully we find a solution.
  4. #4
    When it showed 0% unknown it means to me that the N7 main software is not getting info from the battery software. The battery chip and software are separate from the main system. Possibly bad connection. If the situation didn't get corrected I would exercise warranty or return rights. When she tries to charge it does it still say the same thing?
    Sent from my Nexus 7 using Android Central Forumexercise
  1. Tried and true fix for battery issue
    By andyandroid in forum Verizon Droid Incredible
    Last Post: 05-19-2010, 02:00 PM
  2. Koush's Rom Battery Issues
    By tuxedojacob in forum Motorola Droid Rooting, ROMs and Hacks
    Last Post: 05-04-2010, 10:59 AM
  3. Droid Restart/Battery Issue
    By Dapke36 in forum Motorola Droid
    Last Post: 02-09-2010, 11:40 AM
  4. Odd Gtalk issue on the N1
    By Jeremy in forum Android Applications
    Last Post: 02-05-2010, 09:22 AM
  5. Weird Battery Issue?
    By jacob.downey in forum Google / HTC Nexus One
    Last Post: 01-30-2010, 03:24 PM
