when charging the Nexus 7, should you let it run out of battery completely, or it does´t matter if it still has charge.
Printable View
Read a lot threads that talk about not letting the battery go down to zero because people have had problems getting the N7 to turn back on.
Sent from my Nexus 7 using Tapatalk HD
So approximately at what percentage should you start charging?
I usually charge when I get to 30-40%.
Sent from my DROID RAZR using Android Central Forums
