Results 1 to 8 of 8
- 01-29-2013, 12:11 AM
Thread Author #1
Need help! Nexus 7 no os installed and then some
Hi guys,noob problem here.
Problem:
my nexus died while i was watching a youtube video but my battery is still 30+% when i plugged my charger turned it on,it only got to the lock screen and and then it died again. but this time it has the static on the screen so i panicked. i went to the twrp recovery and wiped the cache,dalvik and accidentally wiped the system. now i have it's showing "no os installed,do you still want to reboot?". at this point,i dont know what to do. i read forums and guides to restore the factory image. i downloaded them and tried flashing it from my nexus toolkit 1.6.2 and it's taking a very long time to "waiting for your device to finish booting back up" and i tried it on the coomand prompt too but failed "too many links" message showed up. everytime i go to the bootloader and flash the stock image it always "hangs",the volume up and down wont work,its always on the "start".
oh and when i went to the command prompt to check for adb devices,my device doesnt show up.
i really need help,are there any step by step guide for dummies?
i'm sorry if the question is a little unorganized,i'm panicking,did i miss anything? please help
thank you! - 01-29-2013, 02:07 AM #2
- 01-29-2013, 02:39 AM #3
- 01-29-2013, 07:58 AM
Thread Author #4
- 01-29-2013, 09:16 AM #5
Re: Need help! Nexus 7 no os installed and then some
Have you tried to mount USB storage through twrp? And transfer a rom to install? If you do this, make sure you reboot back into recovery before you install the rom (hard people have issues trying to install without the reboot)
HTC One X AT&T
Viper XL 3.2.4: ROOTED 2.20 : Hboot 1.14 : S-OFF!
Nexus 7 - Dirty Rootbox v2.0
If I helped you out, hit the thanks button on this post!
- 01-29-2013, 07:51 PM
Thread Author #6
- 05-11-2013, 09:36 AM #7
im sorry to disturb you but can you help me with my problem?can you go to my thread ?Nexus 7:I accidentally removed all ROMs... and it says "no OS found"
thanks?? - 05-11-2013, 09:46 AM #8
As mentioned above, you might be better off ask this question in xda-developers.com
Help! I have no roms installed and am unable to install any.
By unclefarkus in forum HTC EVO 4G LTE Rooting, ROMs, and HacksReplies: 15Last Post: 01-27-2013, 07:15 PM -
Need help to stop auto-updates and apps installing themselves
By tunie in forum AT&T Galaxy S IIReplies: 10Last Post: 10-26-2011, 06:50 PM -
need help !! first time using adb and cmd
By qudwls6933 in forum Thunderbolt Rooting, ROMs, and HacksReplies: 6Last Post: 05-16-2011, 09:30 AM -
Need Help With Google Voice Installation.
By DeadPool in forum Verizon Droid IncredibleReplies: 4Last Post: 09-03-2010, 09:30 AM -
Need help with emailing on phone and outlookexpress
By tmax1964 in forum Motorola Droid XReplies: 6Last Post: 08-05-2010, 09:10 PM
Reply
