Results 1 to 7 of 7
- 02-05-2013, 10:22 AM
Thread Author #1
Tether Nexus 7 to PC using the USB cable supplied
I have searched for the answer to my question with no luck so here goes.
When I use the USB cable that came with N7 the icon shows up on my PC screen. If I click on the icon the PC I think is searching but finds nothing.
I saw where I was to turn something on in the N7 which I did not find. I went to wireless & Network but did not find anything so i clicked on MORE.
This brought up the airplane, VPN, NFC AND Android beam. How to I get the N7 to work with my PC so I can transfer some spreadsheets from
my PC to the N7. Thanks for any help with this.
Max - 02-05-2013, 10:28 AM #2
Re: Tether Nexus 7 to PC using the USB cable supplied
if all you want to do is copy files, plug the N7 into the PC, then go to my computer. It'll show up in the drive list under "media devices"
- 02-05-2013, 12:49 PM
Thread Author #3
i can see the nexus 7 icon on my computer. That is not the problem. When I click on the icon it looks like the computer is searching for something.
The problem is it can not find what it is looking for so what do i do so the computer connect with the nexus 7? Is there something I have to change
in the nexus 7? Thanks again
Max - 02-05-2013, 12:54 PM #4
is the device unlocked when you're doing this? (i.e. sitting on the home screen, not on a lock/password screen)
- 02-05-2013, 02:05 PM
Thread Author #5
- 02-05-2013, 02:31 PM
Thread Author #6
- 02-05-2013, 04:01 PM #7
What are you referring to you when you say "home page?" If you have your Nexus 7 folder open on your computer, yes, you should be able to use copy and paste to move files over to the device.
If you're still having trouble connecting the Nexus 7 to the computer, go into the Settings menu. Select "Storage," then the menu button in the top-right corner (three small squares), then "USB Computer Connection," and finally ensure that "Media device (MTP)" is checked.
Represent yourself well; you never know what might happen. We are a species of moonshots.
Softbricking be damned.
Wifi to Android to PC using USB
By Bact3ria in forum Android ApplicationsReplies: 1Last Post: 02-28-2012, 08:15 PM -
Words from someone who claims to have used the Nexus Prime...
By CZ Eddie in forum Verizon Galaxy NexusReplies: 5Last Post: 10-15-2011, 12:01 PM -
unable to conenct to pc using usb
By nyjw in forum Verizon Fascinate Rooting, ROMs, and HacksReplies: 4Last Post: 02-05-2011, 10:21 PM -
Cannot connect to PC using USB Y-cable
By RyanD8 in forum Fascinate AccessoriesReplies: 0Last Post: 09-18-2010, 01:45 PM -
I got my Nexus One last night, but the USB cable it came with does not fit!!
By Shinwei in forum Google / HTC Nexus OneReplies: 4Last Post: 01-08-2010, 10:41 AM
Reply
