Results 1 to 6 of 6
- 02-24-2013, 02:31 PM
Thread Author #1
Nexus 7 cuts out - battery 35%
This has happened twice now - my Nexus 7 cuts out with a millisecond of white noise and fuzzy screen. I have difficulty switching it back on. When I do get it to boot up it just keeps cutting out (battery around 35%) l've had to do a clean wipe and reboot to get it to work. Is this a common fault? It's getting annoying now.
- 02-24-2013, 02:36 PM #2
Re: Nexus 7 cuts out - battery 35%
Other people have reported similar issues. Do a search and you should see their solutions.
- 02-24-2013, 05:23 PM #3
Fully charge, turn it off overnight, and in the morning it should drastically decrease, then fully charge again and you should be fine
Sent from my Samsung galaxy s3 running AOKP 4.2.2
No,you did not misread thatAndroid is a tune up sports car with custom interior, sound system, and IOS is a stock model benz
I use Android, because unlike IOS, i keep my apps in app drawers, and not infinitely cluttered homescreens - 02-24-2013, 09:59 PM #4
- 02-24-2013, 11:45 PM #5
At the time, had charged mine up then left it overnight for maybe 6 hours turned it on, think it was at 6 % when I turned it back on then everything was fine thank God
I think it's something to do with the indicators on the software side
Sent from my Google Nexus 7 running aokp 4.1.2, because cyanogenmod is the rom for noobsAndroid is a tune up sports car with custom interior, sound system, and IOS is a stock model benz
I use Android, because unlike IOS, i keep my apps in app drawers, and not infinitely cluttered homescreens - 02-25-2013, 05:56 PM #6
Any update on this? Is it fixed?
Sent from my SPH-L710 using Android Central ForumsAndroid is a tune up sports car with custom interior, sound system, and IOS is a stock model benz
3g data cuts out
By ccrs8 in forum LG Optimus SReplies: 7Last Post: 12-05-2010, 07:53 AM -
Will cutting the battery pull tab void my warranty?
By spooksmcgee in forum Motorola Droid XReplies: 3Last Post: 10-14-2010, 03:59 PM -
LED Notification cuts out after so long...is that normal?
By Eazy123 in forum HTC EVO 4GReplies: 6Last Post: 06-29-2010, 07:11 PM -
Swapping out Batteries on the EVO 4G question??????
By Robbie317 in forum HTC EVO 4GReplies: 0Last Post: 06-26-2010, 09:07 AM -
HTC Legend has slide out battery.
By oOoBoNgOoO in forum HTC LegendReplies: 5Last Post: 04-08-2010, 09:42 AM
Reply
