Results 1 to 2 of 2
    dougltc's Avatar
    Posts
    Global Posts
    299 Global Posts
    Default How: control how 'system UI' uses the GPS
    I noticed while indoors recently that my N7 was searching for GPS continuously for over an hour which I assume was draining my battery faster...
    I assumed that it would timeout but it never stopped until I went outside.
    I long-pressed on the notification tray item and selected App Info to see which app was the offending party and found that it was 'system UI' with a jelly bean icon...
    Questions:
    Is there any way to set a timeout or figure out why it is searching for GPS?
    Are there any apps to control this annoying behavior?
    If there isn't a remedy, how do I change the permission to force the system to ask for permission to access the GPS?
    Thanks!
  2. #2
    Default Re: How: control how 'system UI' uses the GPS
    Why not just turn off the GPS? Go to Settings > Location Access > GPS Satellites, and uncheck it. When you have a specific need for GPS when using an app, turn it on again.
  1. Replies: 1
    Last Post: 11-09-2012, 08:35 AM
  2. So what's the deal using the GPS?
    By expidia in forum Verizon Droid Charge
    Last Post: 06-28-2011, 07:14 AM
  3. How-To repair your bootloader after using the 2.1 RUU
    By Jerry Hildenbrand in forum HTC Hero Rooting, ROMs, and Hacks
    Last Post: 07-16-2010, 08:48 AM
  4. EVO 4G - how's the GPS, and can it USB tether?
    By dburr in forum HTC EVO 4G
    Last Post: 06-04-2010, 02:20 PM
  5. How do you type "?" using the physical keyboard?
    By Fat Fingers in forum Motorola Droid
    Last Post: 02-20-2010, 05:32 PM
