A
AC Question
When I had my Samsung, whenever I put it on the charger, I would hear a click noise, like it was letting me know it was charging. Is there a way to do this on the pixel?
Mine is on and makes no sound. It's quite mind bogglingYou should be able to if you go into the Sound section in the settings, click on other sounds and then toggle charging sounds to on.
