Page 1 of 3 123 LastLast
Results 1 to 25 of 51
Like Tree8Likes
    estebancam's Avatar
    Posts
    Global Posts
    1,024 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Galaxy Nexus Sound Quality
    I am not speaking about the audio quality when making a phone call, but in the audio quality for music.
    I am going to use my phone for music quite a bit, and I am wondering about the sound card quality on the Galaxy Nexus. The iPhone has always been better in this regard than any Android phone I have tried. I am wondering if the Galaxy Nexus will be the change to that, and I am really hoping for a great sound card inside the Nexus.
    Anyone know any details? This is one thing none of the reviewers hit on.
    I'm hoping that when AC does their review, they will try to crank up some music on good heaphones or good speakers.
  2. #2
    khuujo9809's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Galaxy Nexus Sound Quality
    My Droid incredible sounds way louder than any iPhone
  3. #3
    solido888's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Louder does not equal better.
    My fascinate has a Wolfson DAC I believe, the same card that is in the 5th generation iPods. I could be wrong, but I think that is the best card apple has used. No clue about the GN
    Sent from my SCH-I500 using Tapatalk
  4. #4
    sushiglobster's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Well, given that the HW specs of the GN aren't all that jaw dropping, I wouldn't be surprised if the DAC was of a lesser quality. The GN was built to tout ICS as an operating system, not be a beast to control all other beast phones, sadly.
  5. #5
    Lucki's Avatar
    Posts
    Global Posts
    267 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Lets just hope it is louder than the Nexus s was because I could not hear netflix in a room full of people @ max volume. Had to be like dead quiet -_- smh.
  6. #6
    Andrew Ruffolo's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock
    Anyone else ever use an OMAP 4 device? How is the sound? They all use the same audio codec. No info on the speaker and if it is used by any other devices... I'm actually surprised and delighted this isn't a typical samsung device except the display. Should prove to be an awesome device overall (Hated everything about the Epic 4G except the screen and GPU).
  7. #7
    ottscay's Avatar
    Posts
    Global Posts
    1,021 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    In my experience on Apple and Android products the two biggest influences on sound quality are the amount of compression (the bitrate in your mp3) and the headphones/earbuds you use. Most ear buds simply cannot create compelling bass - regardless of DAC quality - unless they create a seal (this also blocks outside noise well), and this is true regardless of the quality of the driver as well. The physics of sound makes is hard to effectively create long sound waves (i.e. deep sound) from such a small driver without isolating the listening area (i.e., having it seal within or around your ear).
    Over the ear headsets can produce excellent sound (they also of course are isolating the listening area), but a lot of people don't like them because they take up more space and are more cumbersome on the go.
    So the short answer is either should be equally good unless you are using lossless audio and $200+ listening devices that either create a seal around your ears (either over the ear, or in-ear).
  8. #8
    solido888's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Lossless audio is for archiving. V0 is beyond transparent
  9. #9
    overfloater's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by ottscay View Post
    True (though I'm not sure you quite need to go to $200+ headsets), but the key word here is still "should".
    I just returned a Droid Bionic -- it had several flaws, which have been well detailed here and elsewhere, but the absolute deal-breaker was when I finally loaded up some music and was hit with an incessant, high-pitched whining/buzzing that was clearly down to poor internal shielding somewhere. Admittedly I'm a little pedantic about my audio and I'm also pretty sensitive to high frequencies, but it was astounding to me that a $600+ media device could get through the QA process without such a glaring hardware fault being caught.
    So, while there *shouldn't* be any problems with the Galaxy Nexus audio, I'm still hoping a reviewer finally thinks to plug in a set of headphones and check for us!
  10. #10
    kharrigan's Avatar
    Now using God's Phone
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    4.0.x
    I assume that the priority of sound quality would be the same as the Nexus S. How was the sound quality on that device? (Please note that I did a search and did not find any posts that reviewed SQ on the Nexus S.)
  11. #11
    truemobius's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    here is info about the audio chip on the OMAP 4
    http://omappedia.org/wiki/Audio_Drive_Arch
  12. #12
    krohnjw's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The Nexus S uses the Wolfson DAC - I wouldn't be surprised to see it make a reappearance on the GN.
  13. #13
    ro1224's Avatar
    Posts
    Global Posts
    37 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    On my rooted EVO (CM7 ROM), there is DSP Manager. This app gives me a great deal of options for customizing the sound output. A workout mix I created a while back sounded awesome over my Plantronics Backbeat 903+ Bluetooth headset.
  14. #14
    briankurtz79's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I use dsp manager with cm7 and I've never heard anything louder or better with the proper settings. (Evo 4g with headphones) as far as external speakers I haven't heard a speaker crappier than than the iPhone/ipad. Never been able to hear anything off a friends iPhone in a room full of people playing a YouTube video. And ipad? Low quality mono speaker compared to the 5.1 stereo speakers in my tab 10.1. I just don't understand how people can think the iPhone has any audio hardware better than current android high end phones.
  15. #15
    TechJunkie#AC's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    CM 7.2/ Chad's Kernel
    Quote Originally Posted by khuujo9809 View Post
    My DINC sounds amazing compared to any iPod or iPhone and a lot of other portable devices. I have ~300 ALAC (Apple Lossless) songs loaded onto it through Easy Phone Tunes. Why ALAC? Because I use a 160gb iPod in my car for storage (I have an external processor for DAC) and it's easier to just keep iTunes to sync everything.
    Between DSP Manager and PowerAmp's settings you can get any sound you want. Even without DSP Manager PowerAmp gives you enough control to manipulate the sound anyway you want especially in the 2.0 beta. A lot of my friends who just want bass have been blown away by the bass knob on PowerAmp and I'll admit it does a great job at pleasing bass heads.
    I use Ultimate Ears Triple Fi Pros as my portable music headphones and they get driven nicely with the phone. I've never needed to go above 85% and that's even on deck at loud swim meets. Distortion doesn't kick in until 95%. Most headphones won't have a problem unless they don't have a built in amp but if you get any of those you will know what you're doing.
    In order of my preference of hardware to drive my Triple Fi's. Asus Xonar Essence STX > DINC > HP Envy 14 w/Beats (Such a gimmick) > Creative Zen > HP TouchPad w/Beats > iPod Touch 3G > iPod Classic
  16. #16
    radgatt's Avatar
    Posts
    Global Posts
    1,495 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock
    Here is to hoping that all concerns will be answered when this phone hits shelves...
  17. #17
    TuxDotKing's Avatar
    Posts
    Global Posts
    218 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    BB v0.6.1 (D), CM7 (N)
    Surprised no one's mentioned Voodoo Sound yet. It's definitely a mod worth flashing a custom kernel for.
  18. #18
    racedog's Avatar
    Posts
    Global Posts
    679 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I've wondered about the audio for the Nexus but I wasn't all that concerned about it. I agree that earbuds are the way to go. I have a pair of Shure 500 series and they are phenomenal. They require learning how to insert them because they need to shut off exterior sound. Learning to insert is not all that hard but they used to sell for $500. I don't know if they are cheaper now but they are the best sounding earbud/phones I have every used.
    I never play audio through the phone speaker so I really don't care about that. I also use bluetooth to play music through my car system.
    ottscay likes this.
  19. #19
    lionsson's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    PowerAmp that's all you need to now.
  20. #20
    xolanir's Avatar
    Posts
    Global Posts
    347 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Cool Re: Galaxy Nexus Sound Quality
    Quote Originally Posted by TuxDotKing View Post
    The voodoo sound app will do wonders for the GN once the kernel source is released. I'm pretty sure at this point we can't definitively say what the audio quality will be until it is released.
    roscko likes this.
  21. #21
    pushdrops's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    The Samsung Epic Touch Galaxy II has a pretty decent (loud) external speaker. Loud and clear enough to listen to podcasts across a room.
    The Charge and Galaxy S have super low volume speakers, i was surprised at the volume of the ET.
    The thunderbolt and incredible to me at least have weak speakers just like the Charge and Galaxy S.
    I'm not referring to quality here but loudness to listen to a podcast, ringtone.
    I am using the ET wifi only as the sprint network was ultra slow. Had the bionic which had the awful high pitched interference deal using the analog out. The bionic had decent loudness to the speaker.
    I hope the Galaxy Nexus has a speaker that's as loud as the EpicTouch. I wish Verizon would've just in September had released a Galaxy II device....
  22. #22
    Adrynalyne's Avatar
    Account Deactivated
    Posts
    Global Posts
    1,822 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by xolanir View Post
    I doubt a mod meant to properly take advantage of the Wolfson DAC is going to have much point on the Galaxy Nexus.
  23. #23
    majorhunadadun's Avatar
    Posts
    Global Posts
    60 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I'm very concerned about this, I can't imagine them releasing some shotty but it could be... I'm on an OG EVO and the best sound quality I've had to date is running the Sense 3.5 Runnymede port with the Dre Beats sound enhancement and DSP Manager. I use a $4 pair of Palm Pre headphones which in themselves sound quite good!
  24. #24
    kharrigan's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    4.0.x
    Quote Originally Posted by majorhunadadun View Post
    No offense, but...
    Using $4 headphones just cannot be conducive to forming a credible opinion.
  25. #25
    Posts
    Global Posts
    60 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by kharrigan View Post
    No offense, but...
    Click to view quoted image
    None taken my friend! If I had said they were $150, would that have made a difference?? I've tried many good sets of phones and I've mixed quite a bit of music and I also listen to a lot of music so I have a fairly discerning ear. These phones sound great! Trust me. The point is/ was that if I can get it to sound good on my og EVO then surely I can get it to sound good on the GN. Oh and also you shouldn't knock something til you try it!! Duuuude. *hi-five*
    kharrigan likes this.
