How can I tell when Battery is done charging if I have the phone in sleep mode? With my Droid Incredable the Led would change from red to green. That doesn't seem to be the case with the Nexus.
the lightning bolt goes away on mine.. the battery jus turns solid white. I agree it should be green though
It is also on the lock screen as a percentage. It says Fully Charged once charged. (You cannot have owner info entered)How can I tell when Battery is done charging if I have the phone in sleep mode? With my Droid Incredable the Led would change from red to green. That doesn't seem to be the case with the Nexus.
If your phone is on, it says charged on the lock screen. If your phone is off, the battery icon will be solid instead of animated.
