Page 1 of 2 12 LastLast
Results 1 to 25 of 26
Like Tree4Likes
    Default How can I tell when Battery is done charging?
    How can I tell when Battery is done charging if I have the phone in sleep mode? With my Droid Incredable the Led would change from red to green. That doesn't seem to be the case with the Nexus.
  2. #2
    Default Re: How can I tell when Battery is done charging?
    I'd also like to know. I've been waiting to begin using it. I stuck in in about 8 hours ago, with the phone off, and I still see the white lightning bolt.
    How long did everyone else charge theirs for the first time?
  3. #3
    the lightning bolt goes away on mine.. the battery jus turns solid white. I agree it should be green though
  4. #4
    bplewis24's Avatar
    Posts
    ROM
    Bugless Beast
    The only way I've been able to tell is if:
    1) Charging while powered down, the battery icon will appear solid white with nothing else flashing. If it's still charging, it will slowly flash like a charging battery with a black section indicating how much still remains to be charged.
    2) Charging while powered on, there will be no charge (lightning) icon in the battery. Also going into Settings>Battery will tell you if it is charging or not.
    Brandon
  5. #5
    bplewis24's Avatar
    Posts
    ROM
    Bugless Beast
    Quote Originally Posted by XzombieX66 View Post
    I don't think the LED notification light is working properly yet. I just downloaded Handcent to test the LED and when I press "test" to see it light up, the app force closes. And it doesn't light up for other typical notifications like G+ updates.
    Brandon
  6. #6
    Hearthatvoiceagain's Avatar
    Posts
    ROM
    Stock 4.0.1 Rooted
    I can see this being a popular mod once someone figures it out. If you are used to phones with a notification light that indicates charging its a pain not to have it.
  7. #7
    Mines says what percentage of the battery is left when charging while powered on. I have the GSM version, though.
  8. #8
    I just tap the small power button when powered down and it shows status.
  9. #9
    DCoy82's Avatar
    Posts
    Global Posts
    418 Global Posts
    Download Light Flow app. You can customize the notification light with it including for charging. Works great for me.
    Thanked by:
    BSG75, bjs188 and deandino2359 like this.
  10. Thread Author  Thread Author    #10
    Light Flow is the answer! It will tell you when battery is charging, when it is fully charged, you can set a notification light to let you know when charge drops to a set level, and it will set LED to blink when an e-mail arrives!
  11. #11
    1088933's Avatar
    Androidoholic
    Posts
    Global Posts
    736 Global Posts
    ROM
    AOKP JB 4.1 Franco rr230
    ^^ This. You can have a different color and notification for just about everything, including this issue.
    OG Droid > Droid X > Atrix
    Galaxy Nexus
  12. #12
    Isn't it Ironic that the Fascinate has an audible notification that is very hard to get rid of? Maybe Samsung got too much heat for that?!?
  13. #13
    Quote Originally Posted by herbmmm View Post
    It is also on the lock screen as a percentage. It says Fully Charged once charged. (You cannot have owner info entered)
  14. #14
    baynard17's Avatar
    Posts
    Global Posts
    14 Global Posts
    Try using the app "light flow". It allows you to have the light different colors for charging and charged. I hope this helps and im not repeating anyone. Im playing MW3 and posting.
  15. #15
    I concur with the two above -- light flow! There is a free version, and i love it. It gives different colors, flashing intervals/patterns, customized to specific apps (and sometimes even specific contacts!). I have mine turn bright pink and stay on solid until i unplug it. Works fantastically!
  16. #16
    cj100570's Avatar
    Spoken Word™
    Posts
    Global Posts
    409 Global Posts
    ROM
    Jelly Bean
    If your phone is on, it says charged on the lock screen. If your phone is off, the battery icon will be solid instead of animated.
    It is better to be pissed off than to be pissed on!
    echomouse likes this.
  17. #17
    jwsnj3rd's Avatar
    Posts
    Global Posts
    319 Global Posts
    So your saying the only way to know if your phone is charged is by downloading an app that kinda sucks or am I reading it wrong.
  18. #18
    echomouse's Avatar
    Posts
    Global Posts
    22 Global Posts
    Quote Originally Posted by rschilleman View Post
    Mine tells me the charging percentage and I have my owner info entered.
  19. #19
    echomouse's Avatar
    Posts
    Global Posts
    22 Global Posts
    Quote Originally Posted by cj100570 View Post
    Exactly the same for me!
  20. #20
    tcapote's Avatar
    Geek Freak
    Posts
    Light Flow is awesome. When I am charging, I have my led set to yellow and it turns green when charging is complete. Check it out and support the developer!
    There is no place like 127.0.0.1
  21. #21
    suavehouse's Avatar
    Posts
    ROM
    Stock (Rooted)
    If you're a Takser app user, you can have your Nexus notify you that it is charged in virtually any way you'd like, from playing a sound to LED to speech. Too many options to write.
  22. #22
    Light flow is not working on my gnex any suggestions? And im running stock everything
  23. #23
    As awesome as it may be, i cant support a developer that collects personal data. There is no need for this for the app to work.
  24. #24
    Quote Originally Posted by yummerz View Post
    The program is not granted transmission internet access among it's permissions, only ''read" permissions, so I'm not quite sure how it would transmit your data. You can read the permissions tab .
  25. #25
    How do i find tis app Light flo?
