Facebook battery drain on unlocked Galaxy Nexus
LCW
379
15
Help! Noticing in my battery usage that Facebook is responsible for 15%+ of battery usage!! Wtf?? I've turned off messenger location services in the FB settings as well as the Nearby friends checkbox.
Anything else I can do short on uninstalling the Facebook to prevent this app from sucking my battery dry every day?
This is on an unlocked HSPA+ Galaxy Nexus (just got through google play).
Thnx!
remister
I am noticing the same battery drain as well. But today was my first charge. I will get back to you tomorrow.
Are you having issues on the Youtube App, where the keeps buffering when you are on a Wifi connection?
LCW
379
15
Have not noticed any issues with YouTube over Wi-Fi.I don't have a SIM (waiting on adapter to use my iPhone microSIM ) so I'm using Wi-Fi exclusively at the moment.
drewsg
129
4
18
I don't use the Facebook app on Android because it's notorious for battery drainage. Stick to the touch website, it's just as good as the app IMO
Scatabrain
120
3
Even disabling auto updates and notifications I still had trouble. Removing FB fixed a big piece of battery problem.
LCW
379
15
i reinstalled it yesterday morning... don't know if uninstalling/reinstalling helped... my battery lasted all day (about 15-16 hrs)... will continue to monitor... i'm not trusting it still :confused:.... (refresh set to never)
Scatabrain
120
3
Yuck. Gave it another try today. While I wasn't using it I got a warning it was cranking my cpu. Without going into what FB may have been doing, I won't tolerate the battery hit while I'm not even using it. Removed again.
kirk781
