Page 1 of 2 12 LastLast
Results 1 to 25 of 31
Like Tree2Likes
    kcdee00's Avatar
    Posts
    Global Posts
    120 Global Posts
    Default Mms on straight talk help!
    Guess I'm a dummy but I just can't get my mms working on straight talk!! I think I've tried all the apn setting s on here. Someone who has it working please give me your exact settings PLEASE!
  2. #2
    Jerry Hildenbrand's Avatar
    AC Cowboy
    Posts
    Global Posts
    5,819 Global Posts
    ROM
    Homebrewed
    Default Re: Mms on straight talk help!
    These settings work for my One X and my Galaxy Nexus.
    Attached Thumbnails Attached Thumbnails Mms on straight talk help!-straighttalk-apn.jpg
    Thanked by:
    kcdee00's Avatar
    Posts
    Global Posts
    120 Global Posts
    Default
    I swear that's what my settings are and It just tells me service not enabled on network!! Arrrgh!
    kcdee00's Avatar
    Posts
    Global Posts
    120 Global Posts
    Default
    Anybody else have anything different..????
  5. #5
    Sophos's Avatar
    Posts
    Global Posts
    177 Global Posts
    Default
    Here are mine.
    Attached Thumbnails Attached Thumbnails Mms on straight talk help!-uploadfromtaptalk1342676458925.jpg   Mms on straight talk help!-uploadfromtaptalk1342676476281.jpg   Mms on straight talk help!-uploadfromtaptalk1342676492913.jpg
    kcdee00's Avatar
    Posts
    Global Posts
    120 Global Posts
    Default
    Yep that's my settings! I have checked it 100 times! Thanks for the help, but I think I may have something else going on here. Did you delete the original apn that came when you first put the SIM in? The only other thing I can think of is I used the micro SIM from my iPhone 4s but everything else works so I can't see how that can have anything to do with it.
  7. #7
    vor
    vor is offline
    vor's Avatar
    Posts
    Global Posts
    306 Global Posts
    ROM
    Bigxie
    Might help disclose if you have a Tmo sim or at AT&T one?
    Galaxy Nexus GSM on Tmo Prepaid [ROM] JELLYBEAN bigxie
    Xoom [ROM] Team EOS ICS
    Droid X [ROM] VorteX Reloaded (VXR)
  8. Thread Author  Thread Author    #8
    kcdee00's Avatar
    Posts
    Global Posts
    120 Global Posts
    Default
    Sorry. Att SIM that was cut down to put in my iPhone 4s. When I got the nexus I just used it and data text and phone work perfect just having trouble getting mms to work
    kcdee00's Avatar
    Posts
    Global Posts
    120 Global Posts
    Default
    When someone sends me a message,I get a notification to go to some viewmymessage.com website. When I click on it, the link never opens. If I send, it says the service isn't activated.
  10. #10
    bloo0153's Avatar
    Posts
    Global Posts
    32 Global Posts
    ROM
    Stock
    Use Zmk76's instructions (Post #5). Works for me
  11. #11
    AC Cowboy
    Posts
    Global Posts
    5,819 Global Posts
    ROM
    Homebrewed
    Do you have a stock AT&T APN on your phone?
    You may have to delete it if so. I've looked over what I have here, and realized that I always delete the stock ATT APN when using a straight talk SIM card.
    And I'll ask Mickey tonight on the podcast. He's a G Nex on straight talk pro from wayback.
  12. Thread Author  Thread Author    #12
    kcdee00's Avatar
    Posts
    Global Posts
    120 Global Posts
    Default
    I have tried it with the stock apn and without. I just don't get it...my settings are exactly the same as these on here
  13. #13
    Sophos's Avatar
    Posts
    Global Posts
    177 Global Posts
    Default
    I would definitely delete the original APN and create a new "StraightTalk" one with the setting from this thread. Also, I am using a micro sim in my Gnex so I don't think that's your issue.
  14. Thread Author  Thread Author    #14
    kcdee00's Avatar
    Posts
    Global Posts
    120 Global Posts
    Default
    Ok I tried completely deleting the apn an putting it back in....did not work. Still says service not activated on network when I try to send
  15. Thread Author  Thread Author    #15
    kcdee00's Avatar
    Posts
    Global Posts
    120 Global Posts
    Default
    here's my settings just in case someone can find something wrong
    Attached Thumbnails Attached Thumbnails Mms on straight talk help!-uploadfromtaptalk1342793974526.jpg   Mms on straight talk help!-uploadfromtaptalk1342793993797.jpg   Mms on straight talk help!-uploadfromtaptalk1342794007455.jpg
  16. #16
    Sophos's Avatar
    Posts
    Global Posts
    177 Global Posts
    Default
    When you put the sim back in the iPhone are you able to send/receive MMS?
  17. Thread Author  Thread Author    #17
    kcdee00's Avatar
    Posts
    Global Posts
    120 Global Posts
    Default
    I sold the iPhone so that's not an option. It worked fine when I had it though after the jailbreak. I have taken my SIM out and put it back in and still nothing. Not a huge deal, I just wish I could get it to work
  18. Thread Author  Thread Author    #18
    kcdee00's Avatar
    Posts
    Global Posts
    120 Global Posts
    Default
    Never did get this working. Anyone else have any suggestions?
  19. #19
    I followed the directions in this guys video. Hope it helps.
    Thanked by 2:
  20. Thread Author  Thread Author    #20
    kcdee00's Avatar
    Posts
    Global Posts
    120 Global Posts
    Default
    Thanks, but I have tried those settings....
  21. #21
    if you are able to make calls, recieve texts and send MMS texts/picture texts but just not SMS texts then this might help
    ok id say reset to factory settings because ive never heard of it telling you to go to some site to see your message
    but if u have a lot and dont want to do that you could try this first and if this doesnt work do factory reset and try again
    go to phone mode dial
    *#*#4636#*#*
    click phone information scroll down where it says SMSC and click refresh
    for att sim your code should say 07913121139418f0
    if it does not say that...thats your problem enter that code click update and refresh....reboot phone it can take up to 10 minutes then try sending text
  22. Thread Author  Thread Author    #22
    kcdee00's Avatar
    Posts
    Global Posts
    120 Global Posts
    Default
    I will try that, everything on the phone works except mms
  23. #23
    I am having the same problem. I tried both APN settings with and without the proxy filled in but I still cannot get MMS or data to work. Have you tried a factory reset? I am going that next if I cannot get it to work soon. I have not tried the latest suggestion so I will try that before a factory reset.
    UPDATE: Factory reset worked!
  24. Thread Author  Thread Author    #24
    kcdee00's Avatar
    Posts
    Global Posts
    120 Global Posts
    Default
    I've tried every suggestion here, and nothing has worked....just doing without mms right now and emailing photos..
    I haven't tried a factory reset, the phone was reset when I got it.
  25. Thread Author  Thread Author    #25
    kcdee00's Avatar
    Posts
    Global Posts
    120 Global Posts
    Default
    Oh wow, just replied and saw the factory reset worked for you...which apn settings did you use?
