Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By dmmarck
    Default Power Control widget problems
    My power control widget wont load. Tried removing it and putting it back in, didn't help. Any idea how to fix it?
    Attached Thumbnails Attached Thumbnails Power Control widget problems-uploadfromtaptalk1346599950081.jpg
  2. #2
    Default Re: Power Control widget problems
    If rebooting your phone doesnt work you could try a hard reset....but that would suck. My suggestion is to download widgetsoid from the playstore. It offers a ton of customization options and there is even a way to put the toggles in your staus/notification bar. I used it for a while (before i rooted my phone and got the AOKP toggles) and absolutely loved it.
  3. #3
    skyrockett's Avatar
    Posts
    ROM
    4.1.2 stock JB
    get this
  4. #4
    Hmm that's interesting. Mine looks like that for a few seconds after a boot, but it loads every time.
    LG Nexus 4 // T-Mobile
  5. #5
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Default
    Try clearing the cache and data of the individual app/widget in Settings>Apps.
    Sent from my Overly Suspicious Robotic Grouper
    BlueSauce likes this.
  6. #6
    Default
    I like SwitchPro Widget because it can be placed as a Widget or also as Notification Bar toggles-->
