Results 1 to 9 of 9
    Post increasing sound volume
    Hey all. I just wanted to ask if there are any ways to increase the volume of the ringtones and such on my gnex. Volume+ isn't compatible with jelly bean and I don't have a rooted phone. Any work around on this issue?
  2. #2
    Default Re: increasing sound volume
    You could always manually up the volume of the ringtones with a ringtone maker/editor.
    There are probably other DSP managers or volume editors on the Play Store also. I don't use one though so I couldn't really make a recommendation.
    LG Nexus 4 // T-Mobile
    Quote Originally Posted by Andrew Martonik View Post
    Thanks for your response.
    I will see if I can manually increase the ringtones in an editor of some sort. Thanks again.
    If anyone else has any other suggestions please post!
  4. #4
    Volume + is a solid solution
    Tapped from my (i9250) Galaxy Nexus via Tapatalkz
    Please read my post.
    Thanked by:
  6. #6
    I use speaker boost and it works great!
    Thanked by:
    bez54
  7. #7
    Quote Originally Posted by pontiac005 View Post
    I use Speaker Boost, too. Works great? Meh. It doesn't work as well as Volume+ did before Jellybean, but it seems to help a little.
  8. #8
    Rooting your GNEX and installing custom rom and using volume patch called NexusLouder might be the best option.
    XDA has pre-packed rooting programs and detail instruction. All you have to do is download it, connect your phone to computer and run it.
    I took that route and I'm really happy with overall volume level. I don't have precise measurement but it became as loud as my old Mytouch 4G.
    -NexusLouder
    Quote Originally Posted by DubbingHammer View Post
    -NexusLouder
    Thanks but I don't want to root my phone.
  1. increase music volume?
    By mrhankey184 in forum HTC EVO 4G
    Last Post: 04-02-2011, 01:02 AM
  2. Atrix Sounds Volume?
    By experiment626 in forum AT&T ATRIX
    Last Post: 02-23-2011, 12:31 PM
  3. [Question]How To Increase The Volume?
    By gizmosears in forum LG Optimus S
    Last Post: 12-17-2010, 11:42 AM
  4. Gripes: Brightness and Sound Volume
    By monkeysuncle in forum Verizon Fascinate
    Last Post: 10-08-2010, 03:13 PM
  5. Replies: 0
    Last Post: 08-25-2010, 09:32 AM
