- 11-17-2012, 07:19 PM
Thread Author #1
- 11-18-2012, 08:01 PM
Thread Author #2
- 11-18-2012, 08:10 PM #3
Re: Major 4.2 Problem - Data Signal
I've had it happen too. Sometimes it just won't turn on at all.
Sent from my Galaxy Nexus using Tapatalk 2 - 11-19-2012, 09:36 AM
Thread Author #4
- 11-19-2012, 09:48 AM #5
Updated my phone last Thursday. I have been having the same problems and am constantly losing service and experiencing random reboots. I've also received errors when trying to check my voicemail that my voicemail # is not found on the SIM. I just got off the phone with Google who said they are aware of the issue. They recommended going into my settings>apps>all>google service framework> and clear both cache and data. The next step, if this fails to solve the problem (I will update after a day or so) will be a factory reset. Interestingly, they transferred me to Samsung, and Samsung wasn't even aware that the 4.2 update had gone out and so recommended the factory reset right off the bat.
- 11-19-2012, 12:49 PM #6
Wow...I thought it had to be T-Mobile but yes I think I am having this issue too. It has only happened twice but in my case my signal bars become grayed out and I can't get any 2g or 3g service on my phone. Turning the phone off and pulling the battery fixed it which is what made me realize it probably wasn't T-Mobile...
Sucks. I really thought I'd managed to avoid the issues with 4.2 :-( - 11-19-2012, 07:23 PM #7
Seems to me I now get edge (2G) in places I used to get T-Mobile 4g. Not sure what to make of this or how to fix
- 11-19-2012, 10:08 PM
Thread Author #8
I haven't had a problem with the data signal while it is connected. The issue seems to be happening about 1 time per day. I still get phone service but no data whatsoever unless I reboot.
At the end of the day I guess it isn't too troubling for me personally, but for people who rely on push notifications for email or other things this is a huge issue. - 11-19-2012, 10:39 PM #9
Next time it happens try Airplane mode on, then off. Should come back. I've done that a few times lately with my Gnex on 4.1.2
Is everyone on T-mobile that has this problem? (I am on t-mobile)quick
Nexus One (T-mobile)
Galaxy Nexus (T-mobile)
- 11-19-2012, 10:53 PM #10
- 11-19-2012, 11:04 PM #11
Fingers crossed i've not had a total failure of data signal but I am getting the odd loss of connectivity to the Google servers and the bars go grey briefly but retain the H connection. It comes back very quickly. Just appears to be a bit odd.
- 11-19-2012, 11:15 PM #12
- 11-19-2012, 11:39 PM #13
- 11-19-2012, 11:47 PM #14
I've been watching the forum to see if I should update my GNex or wait (already updated my Nexus 7)...
Just thought I'd put it out there that I have also lost my T-Mobile data connection on my GNex a few times in the last two days, requiring reboot, and I have NOT yet updated to 4.2... I am still on 4.1.1 with AOKP. So maybe there is also something going on with T-Mobile. - 11-20-2012, 12:13 AM
Thread Author #15
- 11-20-2012, 12:15 AM
Thread Author #16
- 11-20-2012, 02:56 AM #17
- 11-20-2012, 04:33 AM #18
T-Mobile for me, BTW ...
Have now experienced a couple of reboots. This AM, was updating a couple of apps (HD Widgets, Ally Bank) over Wi-Fi and got a reboot then "Fuse Locator Failed [something like that]". Since I was on Wi-Fi at home I just ignored it and continued with my morning SS&S routine. Got to work and noticed the nothing-but-grey bars and no "H" phone signal display, went to Status and saw weird signal level and ASU values (very large unrealistic numbers), so I knew a power cycle was needed. Came back up on T-Mobile after power on, all bars and "H".
Alex - 11-20-2012, 04:42 AM #19
- 11-20-2012, 05:34 AM
Thread Author #20
- 11-20-2012, 05:41 AM #21
I'm actually having this problem with my Nexus S, which is on 4.1.2. Shortly after the update, it started losing its data connection. The icon showing my connectivity bars becomes a hollow triangle. Switching into airplane mode and back fixes it, but it's still annoying.
- 11-20-2012, 07:03 AM #22
I had this same issue with a bad data connection when I upgraded from 4.1 to 4.1.2. If I remember correctly, I think I booted without my sim card. Then shut down and restarted with the sim. Then I went to settings > more... (under wireless and networks) > moblie networks > Network operators > Then selected T-Mobile. It took several tries I think. But eventually my data problem went away.
- 11-20-2012, 07:18 AM #23
- 11-20-2012, 09:41 AM #24
- 11-20-2012, 10:02 AM #25
OK, so now this is officially a MAJOR PITA. Had the problem first thing this AM and powered off/on to clear it when I got to work. Left it sitting for several hours and just found it off the network again (nothing but grey bars and no "H") AGAIN a little while ago. Airplane mode on/off didn't clear - had to power off/on again. Did the Settings > Apps > All > Google Service Framework > Clear Data thingy after that, JIC.
Now wondering if a factory reset might be required ...
international version s3 data problem- edge signal HELP!!
By sam0621 in forum Samsung Galaxy S3 I9300Replies: 0Last Post: 11-01-2012, 12:50 AM -
Gps/data/signal
By afbar1114 in forum Verizon FascinateReplies: 1Last Post: 02-21-2011, 01:15 PM -
When losing data signal...
By daft.71 in forum General Help and How ToReplies: 4Last Post: 02-09-2011, 12:57 PM -
Major Exchange ActiveSync Problem
By discdoc in forum General Help and How ToReplies: 0Last Post: 07-23-2010, 03:26 PM -
weird problem with signal strength.
By rem_kujawa in forum HTC EVO 4GReplies: 0Last Post: 07-11-2010, 10:02 PM
Reply
