Results 1 to 4 of 4
    sizzlinninja's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Problems connecting Samsung Galaxy Nexus to PC. Please help?!
    So for some reason, I can't connect my Galaxy Nexus to my PC. When I plug it up through the USB, it recognizes it as an "Unknown Device", and it doesn't let me access anything on it. I installed the drivers and installed them from the Samsung website, and still no luck. And even after doing the "Live Chat" on Samsung.com, I had no luck. The "Samsung Agent" wasn't able to figure out the problem either. Also, when I go to my Device Manager and select "Unknown Device", and try to "Update Driver Software", its says "Windows has determined the driver software for your device is up to date". Yet I still cannot access it... Please help me!
    ---UPDATE---
    I figured out the problem. Turns out, the transfer cable that came with the phone was bad.
  2. #2
    luigy323's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Problems connecting Samsung Galaxy Nexus to PC. Please help?!
    I own a GalaxyS2. IM having the exact problems.. I tried the same things you did and nothing. I think the phone is the problem.
    Sent from my SGH-T989 using Android Central Forums
  3. #3
    patruns's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Do you have USB debugging turned on in the developer options?
  4. #4
    Stephen Jensen's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Make sure you have it connected as a media device. When you plug it in, pull down your notification bar to check.
    Also, If you have any kind of problems with connection or battery charging, try another usb cable. They do wear out after a while.
  1. Samsung Galaxy Nexus: Email Problems
    By g-reno in forum Google / Samsung Galaxy Nexus
    Last Post: 02-22-2012, 07:26 PM
  2. Samsung Galaxy S II bricked?? please help
    By britt376 in forum General Help and How To
    Last Post: 02-06-2012, 10:29 AM
  3. issue getting to stock ROM on Samsung Galaxy Nexus
    By dhonious in forum Verizon Galaxy Nexus Rooting, ROMs, and Hacks
    Last Post: 02-03-2012, 08:13 PM
  4. Samsung Galaxy Nexus out doors(hard to read)
    By Dragerman in forum Verizon Galaxy Nexus
    Last Post: 01-21-2012, 12:17 PM
  5. Problems connecting to VPN. Please help.
    By fasst27 in forum T-Mobile HTC Sensation
    Last Post: 08-26-2011, 05:32 PM
