- 01-30-2013, 05:36 PM
Thread Author #1
Galaxy Nexus Charging while not on charger. Help needed
Hello all, I wanted to ask everyone's advice on what to do with my phone.
A few days ago I took my phone off of the charger and I noticed the battery icon still had the lightning bolt still active. I turned the screen off and then magically it turned back on. I figured maybe I'd pop out the battery and power cycle the phone, maybe that would fix it. Well, it did. Then maybe 2 days later the same thing happened all over again, so I decided to follow the same process that I did before but, to no no avail.
If anyone has any suggestions, tips or possible solutions to this problem please let me know as soon as possible.
Thank you in advance! - 01-31-2013, 02:13 AM #2
Re: Galaxy Nexus Charging while not on charger. Help needed
This thread worked for me as well. Good luck!
Unfortunately, that's probably not a battery issue, but instead a USB port issue.
My phone thinks its charging ALL THE TIME
I solved mine by gently(!) nudging the little nib up to straighten it, and haven't had any problems since.
nb
Sent from my Galaxy Nexus using Android Central Forums - 02-01-2013, 06:56 PM
Thread Author #3
GNex charging while not on charger. PLEASE HELP
By Joseph Best in forum Google / Samsung Galaxy NexusReplies: 1Last Post: 01-22-2013, 10:28 AM -
Not charging while powered on?
By Jaredshoes in forum Verizon Galaxy NexusReplies: 6Last Post: 12-28-2012, 03:57 PM -
Help! Galaxy Nexus Randomly Plays Audio On its Own
By isaackendall in forum Google / Samsung Galaxy NexusReplies: 3Last Post: 07-27-2012, 09:55 PM -
Just Scored on a Early VZW Galaxy Nexus! 12/15 IS ON!
By optimus in forum Verizon Galaxy NexusReplies: 99Last Post: 12-16-2011, 11:18 AM -
Charging while off on CM7?
By Supakitsune in forum LG Optimus S Rooting, ROMs, and HacksReplies: 3Last Post: 07-30-2011, 09:22 AM
Reply
