Results 1 to 5 of 5
Like Tree2Likes
  • 2 Post By Zac Miles
    Default NFC Problems with Hyperion 3800mah extended battery
    Hi all, Im checking to see if anyone has any insight to my issue.
    Problem? NFC is not working on my phone when I use my Hyperion 3800mah extended battery (Which, on the battery, says NFC capable).
    How do I know its the Hyperion battery causing the issue? My factory battery allows me to program and read NFC Tags (tagsfordroid).
    I am using a Verizon Galaxy Nexus running AOKP 4.2.1. Are there any settings I am missing?
    Any help is appreciated, thanks all!
    Galaxy Nexus
    AOKP 4.2.1 Toro
  2. #2
    Default Re: NFC Problems with Hyperion 3800mah extended battery
    Quote Originally Posted by Zac Miles View Post
    Make sure the NFC option is enabled on the phone.
    You can do this by going into Settings, and under "Wireless & Networks" choose "More..." then check "NFC"
    If it still does not work, contact the company for the battery and explain your situation, it could be a defective battery.
    I will contact Hyperion, I know its enabled as it works with the factory battery. Ill give it a try and post my findings. Thanks npark.
    Galaxy Nexus
    AOKP 4.2.1 Toro
  4. #4
    No problem, hope it works out.
    I contacted Hyperion. They are sending me a new battery, and they advised me that they did not want me to have to go through the trouble of shipping the old one back and to just dispose of it.
    Very good customer service from Hyperion!
    Galaxy Nexus
    AOKP 4.2.1 Toro
    msndrstood and npark2012 like this.
  1. A problem with keeping an extra battery: the heat! Suggestions?
    By Vance in forum Verizon HTC Thunderbolt
    Last Post: 06-14-2011, 05:49 PM
  2. Does charger cable work with the Seidio Extended Battery
    By ChrisGonzales90 in forum HTC EVO 4G
    Last Post: 04-01-2011, 03:12 PM
  3. Custom DIY Dock for phones with cases or extended batteries
    By Jonagpa in forum Fascinate Accessories
    Last Post: 04-01-2011, 03:45 AM
  4. Accessories that fit DX with Motorola's Extended battery
    By RHChan84 in forum Droid X Accessories
    Last Post: 03-20-2011, 09:07 AM
  5. PROBLEM Seidio Innocell 3500mAh Extended Battery EVO
    By mannyvigi1985 in forum EVO Accessories
    Last Post: 10-21-2010, 05:55 AM
