Results 1 to 3 of 3
    Electric Sheep Dream's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Unhappy Battery going mad. Is that the end of my phone?
    I have a Galaxy Nexus, Android version 4.3
    Recently my droid started doing some weird things:
    - battery draining much quicker than usual (screen being still the most energy consuming)
    - while connected to a charger it will either:
    - not charge at all unless switched doff
    - charge but not display that it is charging until disconnected from a charger
    - display charging icon but after being disconnected battery drops down to 5%
    - when battery low the warning message will pop out every few seconds
    - while switching off it will switch back on at the last second showing battery low message
    - screen keeps waking up every few seconds
    - gets hot while kept in a pocket
    Not all symptoms appear at all times. It's really random. I thought it might be the battery but I bought a new one and nothing has changed.
    Has anyone else experienced similar issues and perhaps found a solution? Or is this the end of my phone?
  2. #2
    B. Diddy's Avatar
    Posts
    Global Posts
    77,890 Global Posts
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Battery going mad. Is that the end of my phone?
    Welcome to Android Central! Check the battery contacts in the phone, and make sure they're clean.
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thank you for a warm welcome!
    I have checked the contacts - they are in immaculate conditions. I did clean them regardless just in case. It seems that they were not an issue - the problem still persists.
  1. A portion of my screen is not responding.
    Last Post: 06-23-2014, 05:52 PM
  2. Simon the Sorcerer 2 is now on Android!
    By SirKnigget in forum Android Apps
    Last Post: 06-23-2014, 05:48 PM
  3. Simon the Sorcerer 2 is now on Android!
    By SirKnigget in forum Android Games
  4. Problems with my s4
    Last Post: 06-23-2014, 09:24 AM
  5. After installing rom my phone is turning off by it self
    By Electrical1 in forum HTC EVO 4G LTE Rooting, ROMs, and Hacks
    Last Post: 06-23-2014, 03:20 AM
