I was comparing 2 external chargers.
It seems like Anker comes out ahead a LOT. Which is great I have never had a problem
But in one conversation they said, not that it gets hot or I don't know what, but they didn't know why they go A to Type C.
Either you should never do that? Or you should never do it with a powerpack? or maybe just their E5 ?
The Astro E5. If the charger is micro A (input) to type c OR micro usb, then there is nothing you can do to change the Type A part?
Could someone help a guy out and possible tell me what they may be trying to say? Thanks
