1. eric0668's Avatar
    I was comparing 2 external chargers.
    It seems like Anker comes out ahead a LOT. Which is great I have never had a problem
    But in one conversation they said, not that it gets hot or I don't know what, but they didn't know why they go A to Type C.
    Either you should never do that? Or you should never do it with a powerpack? or maybe just their E5 ?
    The Astro E5. If the charger is micro A (input) to type c OR micro usb, then there is nothing you can do to change the Type A part?
    Could someone help a guy out and possible tell me what they may be trying to say? Thanks
    11-29-2016 01:41 AM
  2. hallux's Avatar
    I'm not sure I understand what you're trying to say. Do you have a link to the particular conversation? I actually have an Astro E5 battery, and a Nexus 6P. I used the E5 with my phone when traveling, and as long as a proper cable is used it shouldn't be a problem.
    eric0668 likes this.
    11-29-2016 04:39 AM
  1. Insanely great battery life on the V20?
    By jeffhuypham in forum LG V20
    Last Post: 02-23-2017, 12:36 AM
  2. Replies: 2
    Last Post: 11-29-2016, 07:30 PM
  3. Installed apps won't show on my home screen on the Pixel
    Last Post: 11-29-2016, 12:50 AM
  4. Replies: 2
    Last Post: 11-28-2016, 11:49 PM
  5. Fingerprint randomly turns off and on
    By Mihir Bhatt in forum Samsung Galaxy S7 edge
    Last Post: 11-28-2016, 10:46 PM
